Frugel-Horn Mk3
Frugel-Horn Mk3
Old 28th August 2010, 07:24 AM   #41
chris661 is offline chris661  United Kingdom
chris661's Avatar
Hi guys, a little late to the party but nevermind...
For starters, those new cabs look brilliant (congratulations!), and I'm considering building some to replace my (somewhat limited) floorstanders.
Watching with (great) interest.
Chris
My work: www.grimshawaudio.com
Old 28th August 2010, 10:59 AM   #42
fishinjc is offline fishinjc  United States
Could this be scaled for a 166esr? I've been dying to replace my Fostex boxes and this looks a little easier to build then the Austin A166.
Old 28th August 2010, 02:22 PM   #43
doorman is offline doorman  Canada
doorman's Avatar
Having heard the Mk3's, and built the orig. "frugels", There's no doubt the latest version is the one to build, IMHO.
Much less fiddly internals too--
Don
Old 28th August 2010, 02:27 PM   #44
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
If by 'could this be scaled' you mean 'could an entirely new design be worked out from scratch', then technically yes.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 28th August 2010, 03:12 PM   #45
kristleifur is offline kristleifur  Iceland
Roughly, what are the requirements on the driver?
(For instance, could I use the three-inch Omnes BB 3.01 drivers I have laying around?)
Old 28th August 2010, 03:34 PM   #46
Scottmoose's Avatar
Too small.
FH3 is primarily intended for the CHR70, CHP70, EL70, Alpair 7 or FE126En. We can't vouch for other units; although we've put some flexibility in it, it's not really intended to be a free-for-all / stuff anything into it box either.
Old 28th August 2010, 04:45 PM   #47
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
There are no universal designs, but...
From many of the other designs, we know that people want to put different drivers in the box (no matter what the box). In this one, we hope that we can say, "try it, it may well work". We want to know.
We have tried all these (well not the CHP) in the alphas and performance was satisfactory (if you think that is faint praise then consider that our standards are high). These drivers have a fair range of parameters.
For those who will go ahead and try other drivers, look at the key parameters of the specified drivers and if your alternate drivers are inside the envelope formed by the set of TSP then you have a good chance. No guarantees thou.
With a 3" driver you may well have to use a pair per box. Maybe i should try the quad of FF85 i have in FH3 before i install the new set of drivers into the Twin uFonken.
One thing i do know, neither BOFU or FE166eSR will work. One critical parameter kills the idea. Driver diameter > box width
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th August 2010, 05:01 PM   #48
mp9 is offline mp9  United States
I've a pair of 166es-r's an would be interested in following that build. Also curious to know what you don't like about the 166es-r fostex recommended box or did you install them in a fostex bk16?
Btw, i'm located around philly too so if you decide to do the A166 i may be able to help lend a hand on it's angled cuts with my dewalt 10" sliding compound miter saw.
Considered them myself, but don't have good corner space and read of bad results using the standard A166/lower powered amps, plus Ron Clark said they put a good amount of back pressure on the driver so not for wimpy amps. I like my 3watt Fi 2A3 so passed. I don't know how different a redesign of the frugel MkiIII's for the 166es-r would be wrt 3watts of 2A3 power?
Old 28th August 2010, 05:07 PM   #49
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
I happily used my A126 without corners (near backwall), and with small amps (the killer Scott-based 3.2W el Cheapo variant for instance -- 2A3 SE & RH84 too).
I don't think those should hold you back from A166.
dave
Old 28th August 2010, 05:21 PM   #50
Scottmoose's Avatar
Now that's an interesting idea.
Yes, a bit of a hitch, that. And you can't just widen it because the drivers require different things; volume, horn length & flare etc. will all need to be changed, making for complete new box designs from scratch.
A166 should be a good box for the ES-R; that's what I'd be inclined toward too.
Frugel-Horn Mk3Hide this!Advertise here!
The Frugel-Horn Project planet10 Full Range 1225 23rd January 2017 01:15 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
