Frugel-Horn Mk3
Frugel-Horn Mk3
Old 27th March 2011, 02:08 PM   #461
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
As described at the start of the thread, FH3 is not a TQWT, nor is there an 'extra' horn involved. It's a single hypex horn with an internal choke. The driver location is also quite specific.
Old 27th March 2011, 02:18 PM   #462
triode_al is offline triode_al  Netherlands
triode_al's Avatar
I see, - always the problem of jumping on a forum of not grasping details.
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 27th March 2011, 02:32 PM   #463
Squeak is offline Squeak  Denmark
Squeak's Avatar
Are we not into semantics here? What really separates the two?
Obviously the flares works as an extended horn mouth, but you can achive the same effect by putting a TQWT into a corner, although probably not with the same predictability and finesse.
Old 28th March 2011, 09:22 AM   #464
Merkutio is offline Merkutio  Italy
hi guys,
i need an information.
This project ( mk3 ) is really better than others ( mk1 and mk2 )?
I have a pair of fostex 126en and i'm looking for the best ( and easier ) project.
Thanks a lot
Giuseppe
Old 28th March 2011, 01:55 PM   #465
jemraid is offline jemraid  United Kingdom
I've had a few PM's about my opinion of the FH, yes just one at the moment, and this has just occured to me.
I see many comments that say, 'These really do show up a bad recording' about whatever speaker they happened to have made.
I have a 'bad' recording of Fred's Brigg Fair, it sounds glorious through my FH with a CHP-70.
Hmmmm I thought, it's down to the 'easiness' these speakers have about them it's quite uncanny.
Regards - Jim
FH3 build using very simple tools and a point to point Gain Clone with largish power supply. http://www.jasread.com/fh3/index.html
Old 28th March 2011, 02:54 PM   #466
mp9 is offline mp9  United States
Does this design abate "horn delay" vs that of Ron Clarks A126 back loaded horn?
Old 28th March 2011, 03:18 PM   #467
Scottmoose's Avatar
Group delay in a back horn is a function of axial length and its upper corner frequency. Nobody's complained about group delay yet, so make of that what you will. FH3 when used as intended should have a lower Fhm than the A126 though. Different designs, different priorities.
Old 28th March 2011, 04:15 PM   #468
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
There never was a Mk2, and yes better than Mk1
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th March 2011, 04:43 PM   #469
dave
Old 28th March 2011, 04:59 PM   #470
chrisb is offline chrisb
one of these things is not like the other
one of these things is not the same
by a perverse extension of that logic, an open baffle nested into a corner would be horn loaded as well?
Frugel-Horn Mk3Hide this!Advertise here!
The Frugel-Horn Project planet10 Full Range 1225 23rd January 2017 01:15 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright ©1999-2017 diyAudio
