Hi there,
I post this as a way to get some info out there on these drivers I pulled from a Philips console, since I found practically no valuable info on them online. Model is Philips AD2700M, 6" paper cone and suspension, with whizzer cone, AlNiCo motor and octogonal frame. 4 drivers.jpg driver front.jpg driver back.jpg Here are the T/S parameters I measured, averaged from the 4 drivers: Znom 4 ohm Re 3,2 ohm Fs 78 Hz Qms 2,61 Qes 1,38 Qts 0,9 Vas 20,09 l Sd 126 cc SPL 90 dB BL 2,32 N/A I'll first try them on test open baffles to see if I like their sound to know if I should go further with a more serious build, but their high Q might limit me. If anyone has some experience with similar Philips fullrangers, I'd like to hear about it, thanks. Best regards, IG |
#2 |
Hmmm...
I've seen a couple of designs where a vintage wide-range driver is supplemented by a super-tweeter and a 15" bass driver on OB. Works well, as the crossovers aren't in the sensitive human hearing area.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
Try this site: mfbfreaks : Official Site
in the drop-down box 'Luidsprekers' then Passief then Speaker Info, if no luck, try their forum. They are very helpful if you google translate into Dutch. cheers, Grant |
#4 | ||
The only way I tried them so far was in the 2.34 liter box I built to measure Vas and, although bass was severely rolled of with an f3 of ~220Hz, they sounded promising for mids and highs. Quote:
IG Last edited by IG81; 24th August 2010 at 01:54 PM. |
#5 | |
frugal-phile(tm)
The Foster 12" is a nice driver. My measures, IIRC, give me a Qt similar to yours sample size >10 units). These should work well in a ripole. (my plan for Foster attached) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 | |
I'll be putting the Philips in quick and dirty OB's tonight hopefully to see what they can do. You mentionned the Ripole application for the Foster's in the dedicated thread I had a while back, which I might end-up doing. I wanted to measure them before I do anything, which I only did last weekend (still have to build a box for Vas...). I'll have to see if it's better to fill the bottom end with a Ripole or mount them in the same OB as the Philips, but chances are I'll do the Ripole, since I don't have much room, especially not for 3' wide OB's. That and their not quite-suitable Qts. IG |
| What to do with a Philips AD9710 fullrange | boessenkool | Full Range | 26 | 6th March 2011 06:59 PM |
| 8" and smaller fullrange vs 12" and up fullrange in OB | c3conv | Full Range | 11 | 24th August 2010 05:59 AM |
| Speaker cabinet for vintage 12" philips driver | divingboy | Full Range | 1 | 28th December 2008 09:39 AM |
| Cheap Philips fullrange on OB | Calamaro | Full Range | 10 | 16th October 2008 03:50 PM |
| FULLRANGE SPEAKERS (vintage) and one morel mw220 FOR SALE | Lagroute | Swap Meet | 1 | 21st August 2005 09:52 PM |
| Page generated in 0.11334 seconds (74.73% PHP - 25.27% MySQL) with 11 queries |
