How to put 10" Audio Nirvana drivers in 8" speakers designed by Decware?
Old 16th August 2010, 08:59 PM   #1
hebrer is offline hebrer  Slovakia
Default How to put 10" Audio Nirvana drivers in 8" speakers designed by Decware?
I am currently building my second pair of speakers (first was Metronomes with Fostex 127eN, with quite satisfying results) and I face the following dilemma.
I have bought a pair of 10" Audio Nirvana cast frame drivers for which I need to build a fitting enclosure. I am tempted not to build the manufacturer-recommended bass reflex speakers but rather to try the HDT enclosures designed by Decware. But the plans I purchased from Decware are for 8" Fostex drivers.
What do you think of modifying the size of the HDT enclosures to fit the 10" AN drivers? Anybody tried something similar? What principles should be applied when "enlarging" enclosure so as not mess up the acoustics originally finetuned for different size?
Thanks for your opinions.
Peter (Slovakia)
AN driver specification: http://www.commonsenseaudio.com/an10cfspecs.jpg
Decware HDT speakers: DECWARE / High Efficiency Single Driver speaker model HDT
Old 16th August 2010, 09:34 PM   #2
chrisb is offline chrisb
same answer as at Audio Circles forum:
in short, contact the designer directly when contemplating any proposed changes of driver(s) for which an enclosure (other than a simple sealed box) is optimized
kinda burnt out - taking a break
Old 16th August 2010, 11:13 PM   #3
R.I.P.
The modifying principles are based on the relative parameters of
the two drivers in question, but if any of the details of the design
are based on quirks of the original driver they will not translate.
Depending on the parameters of the two drivers it may be easy
to suggest a relevant transform or impossible to say sensibly.
rgds, sreten.
How to put 10" Audio Nirvana drivers in 8" speakers designed by Decware?Hide this!Advertise here!
Audio Nirvana Super Cast 10" (New) ranger3 Full Range 310 5th June 2014 03:45 PM
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
Cab for Audio Nirvana 10" Full Range knightsound Multi-Way 12 1st February 2007 12:41 PM
New 10" FR from Audio Nirvana. maxlorenz Full Range 0 16th July 2006 09:09 PM
Copyright ©1999-2017 diyAudio
