Anybody had any experience with it? Like a lot of the Ciare full range drivers, has a rising response, do they come across like this in real world listening?
HX101 Ciare Breitbandlautsprecher ![]() Cheers, Rob |
#2 |
It does seem to rise a little from 500Hz, though I expect a greater source of response shaping would be from baffle step, where the length of the driver's acoustic centre to the edge of the baffle is significant to a wavelength. At this point, the driver turns from radiating in 2pi (half space, ie, mounted on a wall) to radiating in 4pi, having a spherical radiation pattern. Because of this change, some of the energy projected is "wasted" by not going towards the listener. There are methods of making the response flat again (ie, cutting down the higher frequencies a little).
Hang on, here's someone that explains it better than me... Baffle Step Compensation Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
| Ciare 6.38NdW | krips | Multi-Way | 4 | 15th September 2009 02:06 AM |
| Has anyone tried the Ciare 8.50 NdMR or the Ciare 6.38 NdMR in a front horn? | pk | Multi-Way | 6 | 10th January 2009 09:42 AM |
| Ciare PH250 | sumacSK | Full Range | 6 | 15th December 2007 09:15 PM |
| Ciare CH250 | JoshK | Swap Meet | 0 | 4th June 2007 01:53 PM |
| CIARE speakers | carlodg | Multi-Way | 2 | 25th August 2005 08:02 AM |
| Page generated in 0.07008 seconds (67.77% PHP - 32.23% MySQL) with 10 queries |
