Old 11th August 2010, 10:54 PM   #11
ttan98 is offline ttan98  Australia
I build these drivers in a small cabinet because I want use them as a near field monitor coupled with a sub-woofer. For such a small speakers they throw a large sound stage when compared with my Open baffle speakers, that says a lot about the drivers. At this early stage(<10hrs usage) the treble needs to be tamed, I think it will settle down a little after more hours of usage. I prefer them to my FE167 Fostex.
The cabinet dimensions are 14cm*23cm*21cm(w*H*D), I use a wool fibre for damping
Old 12th August 2010, 08:52 AM   #12
vmps is offline vmps  Malaysia
may i know where did you get them?
vmps
Old 12th August 2010, 10:11 AM   #13
Try this site, that where I bought mine.
davidlouis1983 items - Get great deals on Consumer Electronics items on eBay UK!
Old 12th August 2010, 03:00 PM   #14
pathdoc2 is offline pathdoc2  United States
What's the ebay link?
Old 12th August 2010, 05:51 PM   #15
stoodood is offline stoodood  United Kingdom
I got mine from the same place that ttan98 did. Thanks ttan98 for the details of your speakers. Has anyone got any thoughts or ideas about putting a pair in a Fonken cabinet? I quite like the look of those. I wouldn't have any idea of how to calculate the dimensions bearing in mind the specific parameters of these Chinese speakers. Would Fonkens be something to consider?
Old 12th August 2010, 07:15 PM   #16
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Going by the factory spec., I'd say borderline. Incidentally, I'd be rather careful of assuming the factory specs. are accurate too; there's a glaring inconsistancy between Vas & B*L for example. If the Vas figure is right, then B*L must be rather lower than stated, & visa versa. Generally speaking, I'd be inclined to suspect the B*L figure as being the more accurate as it's easier to measure. What that says about the rest of the figures though is anyones guess. The Audio Nirvanas, which AFAIK are out of the same factory, have often had T/S specs. well away from the published data sheets, so YMMV.
Anyway, Dave can speak best for the Fonken loads; a modified version of the prime might (might) do OK. As they're limited availability etc., I'm not sure it'd be worth doing a dedicated design. Dave?
A ~7 3/4 litre sealed box would give you a nice 0.707 Qtc alignment with a 52Hz F10 based on the factory specs (with Vas adjusted).
Old 13th August 2010, 12:13 AM   #17
Default Image Attached
This is to confirm I have implemented my sealed cabinet see image attached.
Old 13th August 2010, 04:40 AM   #18
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
It will work OK if the factory numbers are close.
See the attachment for required adjustments to the vents.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th August 2010, 06:41 AM   #19
12345chris is offline 12345chris  United States
Hello - I have a pair of these drivers and would like to put them into a simple horn. Has anyone got any ideas?
Old 13th August 2010, 11:32 AM   #20
Scottmoose's Avatar
They might do OK in the Frugel-horn.
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
FS: Kenwood KFC-16595 dual cone speakers (Australia) Brisso57 Swap Meet 0 1st January 2008 11:53 AM
KLH dual cone speakers specs MPM Full Range 0 25th August 2005 02:35 PM
Dual Cone drivers and Line Arrays fr0st Multi-Way 7 3rd November 2004 08:28 AM
Anyone seen the wooden cone speakers? scott wurcer Multi-Way 3 20th May 2004 04:40 AM
