Old 8th August 2010, 05:48 PM   #1
Default Angling of ports and/or drivers?
So, if one were to undertake building an enclosure along the lines of this one, but knew because of placement restrictions that the enclosure would need to be mounted either above or below the planned listening position (possibly as much as 1 1/2'-2' at a twelve foot listening distance), would it be advantageous to cant either the driver, or the ports (or both) to point directly at the desired prime "sweet spot"? Could such modifications result in undesirable side effects in sound reproduction, or is it just a waste of time as the "problem" is not really much of an issue anyway?
A couple of qualifiers...
Let us stipulate these two things for the sake of conversation...
1. The difficulty of construction is not an issue.
2. Angling the entire enclosure is not desirable (aesthetics, read "spouse approval").
Old 26th March 2012, 07:39 PM   #2
fakeout is offline fakeout  Canada
fakeout's Avatar
If there's an answer to this question, my question would be if I wanted to build μFonken, would it make sense to put spikes underneath the speakers only at the front so they're angled up?
Old 26th March 2012, 08:40 PM   #3
frugal-phile(tm)
planet10's Avatar
Certainly a valid approach
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th March 2012, 08:59 PM   #4
chrisb is offline chrisb  Canada
being somewhat familiar with the design, the volume and internal length of ports is included in the calculations, so there'd be a little bit more than simply canting the entire cabinet, but I can't see why not
Dave?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 26th March 2012, 10:17 PM   #5
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
Dave?
To maintain tuning the only way i can see it down, would be to vertically angle the baffle top to bottom, with the top shallower than the bottom. The bottom would need to increase in depth by at least 36mm to accomodate the unfolding of the L-shaped vent. The other option would be to move the vent to the back firing out the bottom or top (top better for the aspect of where the vent opening is on the inside.
It would then have a significant angle, minimum 67 degrees -- quite a radical angle. Might still need an offset placed on a desk or upside down on a wall.
dave
Old 27th March 2012, 06:18 PM   #6
tuxedocivic's Avatar
now, where there some specific questions not yet answered?
Why angle a port? Doesn't seem like there would be a reason if you ask me. Perhaps angling the driver would have some benefit...
Old 27th March 2012, 06:36 PM   #7
frugal-phile(tm)
planet10's Avatar
Off topic split off to here:
The P10-hifi web site
dave
Old 27th March 2012, 06:38 PM   #8
Is there any audible/measurable difference between angling the driver baffle, versus angling the entire cabinet, provided the internal volume stays the same (and no introduced standing waves, etc.)?
Old 27th March 2012, 06:44 PM   #9
frugal-phile(tm)
planet10's Avatar
Only as it affects the diffraction signature of the box.
dave
Old 27th March 2012, 06:59 PM   #10
dave
and on enclosures with array of side mounted slot ports such as the "prime" mini-onken series, an increase in build complexity - it's a lot easier to imagine or draw some of these than to build them
ANGLING FOR 90° - tangential pivot tonearms directdriver Analogue Source 386 20th April 2012 12:51 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Ports Ryan_U Multi-Way 6 2nd November 2004 04:16 PM
"Angling rings"... worth the effort? eRiCdWoNg Multi-Way 16 4th August 2003 09:50 PM
curved ports vs. multiple ports Craig Multi-Way 1 22nd September 2002 07:30 AM
Page generated in 0.11623 seconds (80.51% PHP - 19.49% MySQL) with 10 queries
