I am willing to build a pair of small desctop speakers for my pc. I already have built a nice tripath ta2024 to drive them.
So an option is the μfonken, but i dont know if my fe83en will be ok for this project, and i am not willing to pay 100e for another pair of 3inch .. Any other suggestion? For lets say 2-3max lts cabinet? My target is a mild speaker, not aggressive and pleasant to listen for hours. |
#2 |
My suggestion is to use a fe83en in a 2-3 lts cabinet .
#3 |
You mean the recomended cabinet by fostex? Well i havent heard so many good thoughts about these default cabinets.
Any other thought? |
#4 |
Two fe83en in 0,5 lts and two subwoofers
#5 |
You may want to go to the FullRange forum for this. People there might be able to help you better if you want to stick with a FRer. Zaph has a 5" two way kit sold through Madisound that looks pretty good. It was just recommended for the same purpose on another forum yesterday.
Good Luck, Dan |
#6 |
Hi, Try searching, there loads of threads on this subject,
/Sreten.
#7 |
frugal-phile(tm)
I did some sims. This driver sort of works in uFonken but rolloff is pretty ugly and xMax is exceeded long before 1 W input (2nd sim -- the well behaved curve is FF85).
2-20 litres sealed would be my recommendation... these sim pretty close, you get a slightly smaller bump at rolloff with the bigger box (1st sim). dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Dave - look like you have some kind of box sim that works on the Mac - is this freeware that I can get a cop of ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#9 |
Guys everybody makes the same mistake.. I asked for a small speaker, maximum 2-3liters, so any option with 4 or 5inch drivers simply will not do! i want to place them right-left to my monitor, and so, i dont want to cover all my desk with 2 larger speakers.
μFonkens i think that are the best for this job.. but i find it strange that there is no design using a 3inch woofer for example and a small tweeter.. |
#10 |
I'm not particularly. Main issue is that a 3in woofer is essentially an oxymoron; you can't beat the laws of physics. It will either have a high Fs, adequate sensitivity & miserable power-handling, or a low[er -these things are relative] Fs, greater power-handling (again, these things being relative), but miserable sensitivity.
When you get down to 2in - 3.5in sized drivers, IMO, there is little benefit to going 2-way, viz. a very small midbass + a tweeter. A high quality wideband driver of that size will do pretty much everything the equivalently proportioned 2 way would. On the bottom end it will have almost exactly the same compromises, but no XO means no attendent issues related to such devices, and less components = potentially reduced costs. I use a pair of uFonkens for exactly these duties myself; they're as good as anything I've heard for this purpose, better than most, and even make handy micro-monitors. Annoyingly good actually, within the obvious limitations that you would expect of course. Last edited by Scottmoose; 1st August 2010 at 04:15 PM. |
| Desktop Speakers | ZirconiumZephyr | Multi-Way | 5 | 18th September 2009 07:21 AM |
| DIY Desktop Speakers Suggestions | underwurlde | Full Range | 41 | 13th September 2009 02:53 AM |
| Desktop OB computer speakers | merajsalek | Multi-Way | 64 | 8th April 2009 01:16 AM |
| Building my own speakers | Supa | Multi-Way | 6 | 17th December 2006 10:16 PM |
| Page generated in 0.11045 seconds (75.36% PHP - 24.64% MySQL) with 11 queries |
