Ladies and Gents,
I am proposing to build a small desktop Transmition Line along the lines of the Mark Audio Alpair 5 desktop TL from Henkjan at Juiogo Audio. ![]() ![]() The placement of the driver needs to be roughly (definately on the same face) as shown in the picture. This is because I am planning to put small amp (not decided on the flavour yet) and a digital radio into the box (not too sure of the workings of this yet obviously). The unit will be used horizontally. Does anyone know of any design/plans from the current mark audio range that would lend themselves to my requirements. I am not 100% tied to Mark audio if anyone has any other similar ideas. I am also not 100% tied to TL if anyone could suggest a decent small horn or sealed box or whatever. Has anyone stumbled across any 'all in one box' designs in the past? Thanks in advance, Paul |
#2 |
I would like to build speakers for my computer, so I am at the same place.
I would like to use the CHR-70, CHP-70 or CSS EL-70. My computer sits in the corner and there is an 18" to two foot deep triangular space behind it I would like to use. Ability to incorporate a T-amp board into the design would be a big plus. -Tom- Slightly off topic: Does anyone have any experience with the CHP-70. Does it have the bigger bass like the EL-70? |
#3 |
I would say : follow the original two-separated-boxes as usual .
They can be moved to cope with different ambient and furniture ,not to mention stereo perception and depth . A little shelf for the electronics can be done in style if wanted . A computer as a source doesn't mean that the amplifier has to be digital :not at all ! I find T-amps and similia the less diy-able amps around. Then ,for the speakers ,a one-in-all enclosure can be a real challenge in design if the same target quality (regular stereo two boxes) is the goal . Channel separation lends itself to a system where physical separation is important ,because since electricity is converted to sound ,each source has to be (subconsciously) perceived separated (the brain mixes ). |
#4 |
frugal-phile(tm)
From putting 2 and 2 togther the CHP-70 could probably be considered a precursor to the EL70. Same basket, similar cone, less magnet. Available in Japan & Germany (and from Mark).
The folded half-tower for the CHR70 could be rejigged for the EL70. Steven S has almost finished his set. Starts here. 1st pics about 20 posts later ![]() dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Dave,
I'm considering a build of a MAR-KEL70 or mMAR-KEL70 enclosure. The CHP-70 would be an easier buy here in Europe than the EL70. As discussed in a post above, the drivers are quite similar, the biggest construction difference seems to be the magnet. The TS-Parameters are unfortunately a bit different too, especially the Vas. Can the above enclosures accept the CHP-70 instead of the EL70, perhaps with minor modifications ? Kind regards, Yves D. |
#6 | |||
Lots of non T-line suggestions here!
![]() I'm (also) planning a build that can be used as pc-setup (and as portable 'radio'). I'll probably design a BR using PVC pipe as enclosure material for neodymium drivers myself (not sure which ones yet) for ultimate portability. Quote:
![]() Yves, later on I saw that the designs you are talking about are BR, so this perhaps not the suggestion you're looking for, but; If it's T line you want to give a (first) try (don't know your experience/demands), take a look at the Cheap Trick 193 or 194, very nice price/performance ratio and good driver availability. Last edited by voltcontrol; 23rd July 2010 at 09:54 AM. Reason: adding info |
#7 | |
Regards, Ewan |
#8 |
Thanks BL21DE3!
With your help I spotted the EL70 at Spectrum Audio. I'll go with the EL70 then. Kind regards, Yves D. |
#9 | |
frugal-phile(tm)
BTW: Henkjan has EL70 i believe. dave
#10 |
| desktop TL with 3" driver (with real bass) | Henkjan | Full Range | 26 | 29th January 2011 08:41 PM |
| Finished desktop tl (henkjan/juoiga) alpair 5 | _henry_ | Full Range | 17 | 29th December 2010 05:33 PM |
| Desktop XL - a compact TL for the CSS EL70 | Henkjan | Full Range | 35 | 10th July 2010 04:50 PM |
| Alpair 6 Desktop TL | TeLHannos | Full Range | 8 | 1st July 2010 08:46 PM |
| radioisotopes on your roof | 7n7is | The Lounge | 0 | 4th January 2008 12:10 PM |
| Page generated in 0.13278 seconds (82.40% PHP - 17.60% MySQL) with 10 queries |
