audio nirvana super8 cabinets decision
Old 19th July 2010, 02:44 PM   #11
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
In that case, assuming you do not wish to support your drivers with dedicated woofers, you're more likely to benefit from tuning slightly higher, to get more gain in the ~ 60Hz - 120Hz region, which is where most of the bass energy resides. There is rather less going on below that point; FWIW, my inclination would be to run a BIB with the appropriate Vb, but tuned to a slightly higher frequency than Fs. Terry Cain's original used a 70in box giving a ~140in horn that's 1/2 wave at 48Hz.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 19th July 2010, 04:05 PM   #12
pathdoc2 is offline pathdoc2  United States
I ended up putting the super 8's in a half-chang about 8 weeks ago. They sound better and better. They have plenty of low end. If you live anywhere near DFW please come by and hear them.
Old 19th July 2010, 04:08 PM   #13
http://home.swbell.net/hebert11/3113..._2386730_n.jpg
Old 21st July 2010, 01:32 AM   #14
freddi is offline freddi  United States
freddi's Avatar
my super8 will get Karlson-couplers - perhaps smaller than the 3.3 cubic foot external bulk K12 which outperforms my blh (and Khorn - subjectively)
have run outta room !
this will be the smaller test cabinet for FE206EN and Super 8 and specs for two apertures
first pix from kutter
Parameters:
Gap Slope p q Area Length Wmax
0.25 1.5 3 12 83.6 18.5 12
x w
0.00 0.50
1.00 0.50
2.00 0.52
3.00 0.55
4.00 0.62
5.00 0.74
6.00 0.92
7.00 1.16
8.00 1.49
9.00 1.91
10.00 2.43
11.00 3.07
12.00 3.84
13.00 4.74
14.00 5.78
15.00 6.97
16.00 8.29
17.00 9.73
18.00 11.24
18.50 12.00
Number Two
0.5 2.9 1.08 9.5 131.9 18.5 12
Aperture
x w
0 0.50
1 0.78
2 1.10
3 1.43
4 1.76
5 2.11
6 2.46
7 2.81
8 3.17
9 3.54
10 3.91
11 4.30
12 4.72
13 5.18
14 5.73
15 6.43
16 7.38
17 8.72
18 10.69
18.5 12.00
Old 2nd February 2013, 06:30 PM   #15
kevner1954 is offline kevner1954  United States
ya should go with the 2.8 with 2 3in. ports ,you should have gotten a plans from common sense when they sold you the drivers. ?????? no?
Old 2nd February 2013, 10:03 PM   #16
Scottmoose's Avatar
Hmm. I think the Standard 8 in the CSA 2.8ft^3 box with twin 3in ports is a trifle misaligned, assuming the published driver specs. to be accurate.
Examples for three different vent lengths (3/4in 3in & 6in) attached, with a variation of each for voltage source amplifiers and something with a higher output impedance.
Old 3rd February 2013, 11:45 AM   #17
Default AN super 8's
I'll take a trifle misalignment,as compared to something with multi drivers and crossover that cost $10,000.00 and does'nt sound as good . like I said I have a superzen ,2.3watts per channel . the 2.8 with an super 8's cost $400.00 tops, 99 db sensitivity, is'nt this about maximum fidelity, minimum cost? to us...............
Old 3rd February 2013, 12:45 PM   #18
Scottmoose's Avatar
It can be, but it doesn't automatically have to be. BTW, the datasheet lists as 95.4dB 1m/w rather than 99; back calculating from the published specs., that appears to be correct.
My problem with a misalignment is that by definition, it's not necessary (I was being [very] polite with the 'trifle').
Old 3rd February 2013, 01:02 PM   #19
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Is the misalignment you are referring to the excessive overshoot bump? Could that not be easily fixed by tuning just a hair lower in frequency (tiny bit longer port)?
Old 3rd February 2013, 10:25 PM   #20
Scottmoose's Avatar
Unfortunately not. You can see for yourself. I gave three different example tuning alignments above for the Standard 8 in the CSA 2.8ft^3 box, with both a voltage source & a high output impedance amplifier. Tuning it lower isn't going to make things any better.
audio nirvana super8 cabinets decisionHide this!Advertise here!
FS/FT Audio Nirvana Super 12 Cast Frame drivers in custom cabinets vaughn Swap Meet 12 5th April 2010 01:51 PM
Fostex or Audio Nirvana? mikejennens Multi-Way 17 17th July 2008 02:12 AM
ApexJr super8 fun theNoid Subwoofers 14 1st December 2006 07:16 PM
Audio Nirvana Andy9485 Multi-Way 6 21st November 2006 11:46 PM
Audio Nirvana - Where Is It? How Do We Get There? Bas Horneman Everything Else 9 25th January 2006 02:05 AM
