Old 30th June 2010, 02:20 PM   #1
Default Simple & nice DIY proposal (FX120)
Following my small tapped horn sub build (TH-Micro - a 6,5" tapped horn) it is now time for a set of small (again) satellite speakers to complement them, this is a proposal only, and as such not yet fully investigated.
Take a look at...
Martinsson`s Blog
...and tell me what you think, am I on the right track here ?
Best regards // martinsson
Old 30th June 2010, 03:35 PM   #2
frugal-phile(tm)
planet10's Avatar
The overly small enclosure (i'd suggest 10 litre as a minimum), with wall proximity are likely to cause a big bump in the response. The same + the proximity of the back wall, will likely give a nasal, boxy midrange.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th June 2010, 04:10 PM   #3
Send a message via ICQ to Crossblade Send a message via AIM to Crossblade Send a message via MSN to Crossblade Send a message via Yahoo to Crossblade
Why don't you make a standard bookshelf to sit on top of your subwoofers, as showed in your blog? Using the same width will make it look like a modular two way speaker.
Old 2nd July 2010, 09:03 PM   #4
Planet10 - why not try to break new ground, even if this would prove be a failure (I confess that have my doubts as well) it would still be a rather nice attempt at forging our passion with that of our better halfs
Simulations show no big deviations, but simulations only goes so far, i can see your point and it is indeed a valid one, but bare in mind that i will not be inended for use below 100Hz.
Crossblade - where is the beauty and challange in basic boring old cubic boxes ??? (but I agree, it would be easy and probably sound rather good aswell)
This is a quick rendering of my drawings, the fixing feature on the rear piece facing the wall is slightly different, and I will update my drawings accordingly.
Old 3rd July 2010, 01:53 AM   #5
Nanook is offline Nanook  Canada
Nanook's Avatar
Default er, why not leave the enclosure off?
and try an open baffle if suitable for the drivers
stew -"A sane man in an insane world appears insane."
Old 3rd July 2010, 03:05 AM   #6
frugal-phile(tm)
planet10's Avatar
If you believe the factory specs, the sim says you'll be fine to XO to a pair of woofers at ~120 Hz. My measures are a bit different, and boxes built to test which are more accurate indicate somewhere inbetween.
Factory specs are the flat curves, measured is the one with the big bump.
Careful XO could deal with the FR (this is where the droopy nature of a 2nd order PLLXO could come in handy), but the big issues to my mind is the potential for serious loss of midrange "cuppiness" due to no room to breath.
If you go for it, build a test box 1st.
dave
Old 4th July 2010, 09:41 AM   #7
I'm currently listening to them in open baffles, 470x1000mm driver symetrically placed.
I'm not that impressed sofar, but it has only been a few hours, do they need some break in time ?
Old 4th July 2010, 02:52 PM   #8
Jim Shearer's Avatar
If the FX120 sounds unimpressive, you might consider the amp you are using. I haven't tried FX120, but I have a pair of F120A which sound pitiful on any SS amp I have used. Put tubes on the F120A and they sing very sweetly!
Cheers, Jim
A day without music is like a day without food.
Old 4th July 2010, 03:06 PM   #9
Nanook's Avatar
Default tubes and FX120...
Perhaps ask the fullrangemeister specifically, but methinks a good class T or D amp would be ok as well
Old 4th July 2010, 11:27 PM   #10
Joe H is offline Joe H  Ireland
I'm not that impressed so far, but it has only been a few hours, do they need some break in time ?[/QUOTE]
Mine improved with some break in time for sure .
This weekend I've been playing around with a PC based setup using the FX120 in a smallish ( 8) liter BR . The amp is a Ta2024 inside a topping external soundcard .
I lined up my threeway alongside for some A/B comparisons .. bit unfair perhaps .
So far .. Im definitely impressed by the FX120 s wonderful detail .. it seems to do most things very well . Somethings lacks ... for me that is , compared to my threeway ..I think the its a soundstage thing ... a little lifeless perhaps .. not sure .
Simple AMP DIY 98nassin Car Audio 6 23rd October 2007 10:10 PM
nice and simple mod on BMS tweeter Sjef Multi-Way 0 20th July 2007 09:59 AM
Nice simple parallel bridge config vortech Chip Amps 0 5th August 2005 01:08 PM
Proposal On Single Ended Class-D Subwoofer Amp Workhorse Class D 8 27th January 2004 09:11 AM
Nice and Simple ? djk Pass Labs 2 9th January 2002 09:19 PM
Page generated in 0.11814 seconds (78.19% PHP - 21.81% MySQL) with 11 queries
