Can Any one teel me how to remove the back cover of lowther EX4 ? Thanks! |
#2 |
Have you contacted Lowther to ask? They're a very helpful bunch of people in my experience.
Out of curiosity, why do you want to? |
#3 | |
Bob |
#4 |
use a utility knife to cut that silicon glue. Insert the blade between the back module and the basket. Get as deep as you can. I usually make 3 or 4 passes around, trying to get a little deeper each time. Then use a thin, wide blade, in the gap. Twist, move blade 90 degrees, and repeat. This really minimizes any marking on the driver.
To put the module back on, clean off the old glue (that is the hard part), and put on new silicone glue. Put the driver face down, and align the back module. Then weight the back module with books, weights, clamps, whatever to hold it in place. Silicone takes awhile to dry.
Jon Ver Halen Lowther-America |
#5 |
You are very kind
I'm new here The reason is I want to put them in a Hedlund horn This horn was designed for a dx2 the walls of my horns are damped with felt in this way means i do not need the back of the speaker while the horn will be better loading truth |
#6 |
Hi FRUGIVO,
Without knowing anything about the DX4, more than price, which is enough for me I would try them with the basket first. Anything that keep higher frequencies out of the horn path would be good. Or?Peter |
#7 |
Well, as the cover only reduces unwanted midrange etc., frequencies, & the EX range are specifically intended for use in horn variations, I'd leave it in place. It's unlikely to do any harm & may be beneficial, although harmonic resonances from the horn will still be present of course, these being a characteristic of the horn itself rather than the driver's output.
#8 |
One thing, regarding horns, that I've been thinking of is, why drivers are not measured from the back. Measurment on dipoles shows quite large peaks compared to the front measurments. And I mean near field measurments.
Further on, I discovered ~2.8 k peak with my Sonido horn and Sonido driver. Change driver with similar parameters and peak moved down. Maybe I'm on trip in the ditch, but would not the shape and size of magnet, basket, spider and whatelse matter. Oh well, for once I have the time to waste kb here. Cheers, Peter |
#9 |
as I have not closed one side of the horn
I could try one horn witht damping and another no the difference is noticeable without damping the sound has more presence at the middle but the bas disappearing too with damping all improvement the bas are more marked and clear then now I like to try without the rear so l,d have more references and choose considering the subjective factor when we talk about sound |
#10 | |
exactly this is the way so follow the step and I got it the first one I did with some scares but the second everything was fast definitely in my opinion and my case the back of the speaker is unnecessary I'm testing some time this way I can always return to the original form thank you very much friends |
| Better than a Lowther? | ChrisR1983 | Full Range | 16 | 24th June 2010 01:28 PM |
| cabinet for a lowther ex4 | mjkempton | Full Range | 12 | 23rd September 2007 09:31 AM |
| lowther | tomtt | Full Range | 11 | 8th November 2006 04:08 AM |
| lowther repair? | Zen Mod | Full Range | 0 | 31st May 2006 11:51 PM |
| Lowther EX4 | etalon90 | Swap Meet | 0 | 21st August 2004 06:53 PM |
| Page generated in 0.12830 seconds (78.98% PHP - 21.02% MySQL) with 10 queries |
