Old 26th June 2010, 10:06 PM   #1
hm is offline hm  Europe
hm's Avatar
Default fullrange double horn
Hello,
i made a new construction
simpler as an SAXOPHONE
and less wood than an RDH20
opinions?
http://www.hm-moreart.de
Old 26th June 2010, 10:28 PM   #2
are both horns with their drivers optimized to balance their
impedances in a way to be a more resistive load than a single
one would be ?
An impedance plot of either of the single drivers and both connected
in parallel would be interesting to see in how far the motional
parts of the driver impedances are balancing.
The folding looks nice indeed.
Kind Regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 26th June 2010, 10:38 PM   #3
hm's Avatar
Default Imp
Hello,
yes,
look my KORNETT real
measurements and simulations:
kornettmess
all double horns look nearly the same.
Old 26th June 2010, 10:46 PM   #4
I see,
nice work !
Where is the damping applied ?
www.dipol-audio.de
Old 26th June 2010, 10:51 PM   #5
hm's Avatar
Default soft fiber
Hello,
soft fiber is the key material,
more info:
FDBH20
Old 26th June 2010, 10:55 PM   #6
no fibers in the "air path" or the compression chambers,
just soft walls ?
Kind Regards
www.dipol-audio.de
Old 26th June 2010, 11:02 PM   #7
hm's Avatar
polyester Watte around the driver,
not in the horn throat,
the softfiber reduce inner reflections
over 100 Hz.
Old 26th June 2010, 11:07 PM   #8
Very interesting concept. What do you think about
sheep wool instead of polyester ?
I had good results in conventional speakers with
sheep wool near the driver.
www.dipol-audio.de
Old 26th June 2010, 11:13 PM   #9
hm's Avatar
as you like,
some people like it look:
basstubaFB
Old 26th June 2010, 11:23 PM   #10
Thank You very much for explaining.
Good luck !
Kind Regards
www.dipol-audio.de
double horn, bib or angular spiral horn? testarossa2k Full Range 49 18th September 2011 03:03 PM
Double horn and electrostats. oublie Full Range 8 5th June 2009 01:07 PM
double Horn for FE167 Spassgeneral Full Range 29 20th February 2008 07:37 AM
Kornett double horn hm Full Range 1 4th January 2008 03:20 PM
double horn 108 ? brad212 Full Range 12 31st March 2005 08:07 PM
Page generated in 0.10697 seconds (75.02% PHP - 24.98% MySQL) with 11 queries
