I got a Fonkin' quesion...
Old 26th June 2010, 07:07 PM   #1
aptquark is offline aptquark  United States
aptquark's Avatar
Default I got a Fonkin' quesion...
What is the premise behind this design? And, can it be utilized in a tower fashion?
thanks
Spiro
Old 26th June 2010, 08:00 PM   #2
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
A tower would be somewhat compromised because of the 1/4 wave resonance.
The FonkenPrime has been morphed into a floorstander thou (althou the Mk II was shortened a bit and a false base added), and the Fonken167 (and Mar-Kel^2) are made into floorstanders by grafting on a false base.
The idea is to use high aspect ratio ports to add a nominal resistance to the ports to make them more tolerant of changing T/S parameters with level.
A standard BR assumes that T/S are scalers. In reality they are a curve/manifold F(V,weather) and a tightly tuned BR turns out to be properly tuned in only one place of the curve.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
I got a Fonkin' quesion...Hide this!Advertise here!
2x TDA1541. noise quesion Nick122147 Digital Line Level 48 4th August 2011 09:43 AM
zaph l18/27tbfcg build quesion vcmc Multi-Way 17 8th June 2007 07:55 PM
A quesion about ORCAD part lib????? roberd Chip Amps 4 30th May 2006 07:22 AM
Naive CCS quesion zobsky Tubes / Valves 5 7th August 2004 12:50 AM
