Old 25th June 2010, 06:20 AM   #1
Default Another newbie FR OB question...
Hi!
Just a quick basic FR OB question.
If I was planning to run a FR driver (such as a Alpair 7 or 12 / Fostex / Visaton B200) with a pair of active subwoofers in stereo to fill out the mid to low bass, does the dimensions of the baffle really matter?
I ask this because I have a small room and space is at a premium, and I had pretty much discounted OB as an option.
If I put an Alpair 7 (for example) on a thin baffle just wider than the driver up to seated head height and ran them full range, how low are they likely to get?
I was thinking about supplementing this with either two small sealed subwoofers, or even two to four *small* OB subwoofers depending on size (?Hawthorne 10" Augie / ?SDX) running from a couple of plate amps. Smaller and multiple would be better. There's no way I could manage 15" or 18" woofers ala "MJK Jordan and Goldwoods".
Does this sound reasonable? Would this work okay, or would the crossover from FR on a narrow baffle to pro-audio small subwoofer be too high and compromise the sound? I don't need the bass to go incredibly low or loud.
If this is possible, anyone have suggestions on the FR driver and a suitable small (?10") woofer for OB?
Otherwise I'll probably go a compact TL design, Tysen or Fonken such as those by Planet10.
Any comments would be greatly appreciated!
Thanks!
Taz.
Old 25th June 2010, 06:36 AM   #2
frugal-phile(tm)
planet10's Avatar
The baffle needs to be wide enuff to let the FR/OBs bass reach the woofers -- if you want them narrow you need to think about woofers, not subwoofers.
You will need to roll-off the bottom of the FR -- prefereably in front of the amplifier.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th June 2010, 12:51 PM   #3
Yep... but I'm just wondering how low the drivers would go on a minimal baffle.
On the Mark Audio website it gives a frequency response curve and it seems to roll off below 100Hz, but is that at 1W in free air?
For example, if I mounted the Alpair 12 just on a pole (essentially no baffle), at what approximate frequency would I have to cross in a woofer? Would I get close to 200Hz with the naked driver? 100Hz? 600Hz?
Sorry... but I'm a complete novice!
Thanks for any advice or information anyone has!
Taz.
My FR OB idea Ppasco1018 Full Range 16 29th October 2009 09:53 PM
Different OB designs for woofer + FR FlorianO Full Range 11 2nd April 2007 11:25 PM
Senon FR + Tweeter in OB inrank Full Range 2 1st February 2007 11:09 PM
So much choice- FR + Bass or Coaxial in OB? inrank Full Range 16 1st November 2006 04:49 PM
Visaton B200 vs FR125S in yet another FR+W OB Paul Ebert Full Range 30 22nd May 2006 06:48 PM
Page generated in 0.07349 seconds (70.10% PHP - 29.90% MySQL) with 10 queries
