It's been awhile since I built a speaker and I'm a bit out of date on things,
My amp is a low power SET (6A3 tubes, expect 2-3W) and I want some speakers that will be sensitive enough for regular listening (not looking to recreate a rock concert) in an average Canadian living room. My last project were FE127's in Onken enclosures. They were too 'bright' so I had to add some BSC and now they sound good, perhaps not as lively as I'd like so the BSC maybe overdone. I want something larger with more sensitivity and still a full-range driver. I figure that a larger driver would give higher sensitivity (e.g. >95dB). I want to avoid the need for a tweeter so I believe I should not be going above a 6.5" driver. Hence the Fostex 166/7/8. 1) Is this thinking correct - is this a good driver choice ? 1) Which of these drivers does Fostex still make ? 2) What kind of enclosure is recommended e.g. Fonken167 / BVR (Chang?) / Back loaded horn (Hiro?) ? Thanks in advance !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#2 | ||||
after building more than a few each of many types, I'd opine that even though some of MLTL /BIB or BVR will be larger boxes, they'd be a less time consuming and fiddly build than the floorstanding Fonken for 167 Quote:
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 |
Thanks Chris - I'd really value your opinion on how you perceive the differences in sound (if such a thing can be described) between these enclosure types ?
Which builds represent the 'best' of each class (e.g. for BVR which box appears to have the strongest following for 166/8 - I prefer to use currently available drivers) ? p.s. I'm not concerned about the complexity of the build, I very much enjoyed building the Moon Onkens.
#4 |
#5 |
frugal-phile(tm)
FE166En will go into Hiro, Austin A166, Valiant (think next gen Hiro), or a design requiring a dedicated woofer such as Arpeggio (would probably require some change for the new driver), or the doc bottlehead scheme which is somewhat similar but not as well documented.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
Tom, That's a great article to read, explains things clearly. Shows with simple math the cold hard truth.
Unfortunately, I just don't like the appearance of this design, aesthetically. Edit: Dave, just saw your post.... I'm studying the Spawn Family....says this web page is being updated soon, can you say when ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 26th June 2010 at 02:18 AM. |
#7 |
frugal-phile(tm)
Continuously... a major update on the plans page was done a bit ago... the intro page is behind.
dave
#8 |
The 167's (eNABled, of course!) in the Fonken floorstanders are very fine, IMHO.
The bass is way more taut and better integrated than a previous MLTL cab using the same drivers, albeit not treated. I also heard the "Demetri's" at Dave's, and remember thinking the bass was better controlled than the said MLTL's Have Fun! Don |
#9 | |
frugal-phile(tm)
dave
| Austin 166 | ed2000145 | Full Range | 4 | 15th May 2009 05:57 PM |
| Enclosure for tube amp/speaker/reverb unit | Aidan135711 | Tubes / Valves | 30 | 21st September 2008 06:06 PM |
| Thorens 166 | d to the g | Swap Meet | 0 | 23rd May 2007 01:31 AM |
| midrange and fostex 166 | tenderland | Full Range | 3 | 10th August 2006 01:56 PM |
| Page generated in 0.11846 seconds (77.46% PHP - 22.54% MySQL) with 10 queries |
