Old 24th June 2010, 12:14 PM   #1
Default Alpair 6 Desktop TL
There are these cool desktop TL designs from Henkjan with Markaudio drivers - the alpair5 and the (css) el70.
I already have a needle-tl with a Alp6 and I really like it's sound - and there's another pair of alpair6 at myhand AND I need a computer speakers, since headphones all the way isn't my thing, I realized.
So I wonder if it would be doable to construct a compact size TL with the Alpair6. I've found nothing on the web, so I any hint would be awesome!
Kind regards,
Hannos
PS: I tried to enter the T/S-Parameters of the Alpair5 into the excel sheet provided here: Help a new guy with TL enclosure
But the results for S0,SL and length greatly differs from those I measured from the Alp5-TL construction plan. But I couldn't find out what the TL's tuning frequency is (maybe around 70Hz). I guess it's far below the drivers fres (125Hz). If this is the case, shouldn't be that big difference a problem concerning the whole TL principles?
I have so many questions about TL's, but the TL Theory Papers from M.J.King seems so complicated...
Old 26th June 2010, 01:03 PM   #2
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
the horn-reflex design I did with the Alapir6 is not an option?
I could do a few sims with the Alpair6 for a similar styled desktopTL later this WE (provided I win the my fight with my PCs which are causing a lot of manure lately)
Old 26th June 2010, 06:22 PM   #3
frugal-phile(tm)
planet10's Avatar
Henkjen,
I have a feeling you might find the EL70 TL a good starting point.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th June 2010, 09:59 PM   #4
Hi and thanks very much for your responses!
I didn't know that you did a horn-reflex design. I couldn't find it on the forum. Maybe you can point it out.
It would be awesome if you could construct a design.
In the meantime I tried my luck with my own design and already finished the prototype speaker box.
I'll post all relevant stuff tommorow, so maybe we compare it than.
(I didn't have the "King Sheets" btw, just the excel, so it's gettin interesting )
I'm quite happy with the result - after changing the sonofil stuffing a few times. My prototype still isn't going as deep as the needle, but having a peak at ~55Hz. After 55Hz the pressure level is going down and hits the same level at ~90Hz. This behaviour is a little annoying... missing many of the fundamental tones, the needle on the other hand sounds a little fatter.
The alp 6 seems quite loud from 100Hz-500Hz if I listen to single frequencies.
The needle don't show this behaviour. Can this be because of the trap cirquit at ~2000HZ in the needle ?!?
Kind regards,
Hannos
Old 27th June 2010, 08:59 AM   #5
Here are two photos and the excel tables.
The design is quite like the alpair5 desktop tl. I point to the driver position. I guess it's not a big problem if you shift the mounting of the driver from one side to another, as long as the position on the line length is garranteed.
To the excel table - I brought in a limiting factor to the "line length" because of the dampening material. I hope this wasn't a mistake.
But I guessed that at this point the dampening isn't taken into account by the excel sheet.
@planet10:
The el70 design I considered too big for my desk.
It has to be quite flat (16cm max) and max. 43 cm high. The front aspect wasn't of much interest but the excel sheet tended to the golden ratio...
Kind regards,
Hannos
PS.: I had a small error in my excel sheet. The description for the fields "Correction cross line section" and "Correction of the tuning frequency" were switched. I don't know if this had been fixed at this point.
Old 27th June 2010, 02:24 PM   #6
chris661's Avatar
How does it sound?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 27th June 2010, 08:58 PM   #7
See my secound post in this thread.
There's room for improvement
Old 28th June 2010, 12:37 AM   #8
@Henkjan:
I've found your easter project 2010 .
Maan, if I knew about this before I certainly have built these.
Well, I can still make a computer case or a bird-house out of my box.
Old 1st July 2010, 08:46 PM   #9
Henkjan's Avatar
if you still consider a TL, here's a sketch of something worth trying... stuffing, something like 50grams sonofil, 90% in the closed end, remainder in the open end (adjust the latter to tast)
desktop TL with 3" driver (with real bass) Henkjan Full Range 26 29th January 2011 08:41 PM
Finished desktop tl (henkjan/juoiga) alpair 5 _henry_ Full Range 17 29th December 2010 05:33 PM
Desktop XL - a compact TL for the CSS EL70 Henkjan Full Range 35 10th July 2010 04:50 PM
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 11:48 AM
Can anyone help TL or ML-TL for Alpair 10 _henry_ Full Range 3 31st December 2008 06:31 AM
Page generated in 0.12223 seconds (78.54% PHP - 21.46% MySQL) with 11 queries
