Hi, I'm about to start a new project useing Fostex FE87E or 107's to set as a PC loudspeaker, combined with a T amp. I'm looking for a compact design, like some cubes I've seen googleing... not much info... well, yes there is but in chinese or japanese or other asian language wich I don't understand. Apart from the recomended enclosure at Fostex site (6 litre bass reflex box) do you know of any other with 4 or 5 litre? Any recomendations or experiences are wellcome.
many thanks in advance to all cheers |
#2 | |
Meet the Fonkens has worked particularly well with FE127E : i.e "m" for "milli" (4.5L) ![]() FE103E (no pictures at the moment) fits same sized enclosure, so I can't see why the FE107E wouldn't also and the most excellent and already very missed FF85K : "u" for "micro" (2liters) ![]() this one is a particularly crazy good little nearfield PC monitor - iTunes equalizer can probably approximate close enough to BSC if deemed necessary. detailed plans at first link there is also Tony Gee's Solo103: Humble Homemade Hifi ![]() all above are fairly easy builds and sure don't use a lot of material
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 21st June 2010 at 01:03 AM. |
#3 |
Hi thanks for the reply. I've seen the fonkens, the mini looks great, but i would like it bit smaller (not as small as the microfonken for ff85k ). I mean, I would choose the fostex FE127E but in a smaller box.
Does the FE87E fit in the microfonken box? Well, I heven't heard any of these small fostex's. My only refernce is a FE207E, wich I sold, but I wouldn't mind having them again. The sound was very very very nice and warm for me. May be not as punchie as my actual Scan Speaks, but very nice. that's why I'm looking through fostex's. The best thing would be to have them both FE207E and actual SS, but I can only stay with small fostex's. This kit at Lautsprechershop is more like what I'm looking for. A compact cube speaker, but may be not with Tang Bands (or perhaps yes). I don't know if you have seen this one or hared any thing like it: Cheap trick ct218 Klang ton 5/05 |
#4 | |
well, to be anal about it, we're calling the "mid-sized" box design (which with minor adjustments to vent tuning details has proven to work well with several of the Mark Audio drivers as well) the "milli" I'm fairly sure that there was at least one pair with FE103E installed, and certainly there'd be no issue with the FE87 fitting in the "micro", (possibly requiring adjustment to port dimensions) but I'd doubt it would approach the FF85K in overall performance
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#5 |
Greg Bianchini at Gregg's Karlson speaker forum scaled the 8K - I'll probably have "K4" with FR88ex as a toy then evaluate
"These are both scaled from the 1960's type 2 K8". (50% and 62.5% respectively) full size here: http://lh6.ggpht.com/_74mgsXnFjZ8/TA...z6KL3NU/K4.PNG full size here: http://lh5.ggpht.com/_74mgsXnFjZ8/TA...1NxIhFc/K5.PNG |
#6 | |
Well, to follow up ( and Dave may post on this separately) to achieve the same bass performance from the FE87 as the FF85K handily delivers in the 2 liter micro, would require approx 4liters. So at the time, so unless you already had them in hand, it made more sense to spend a bit more on the FE127E and build the slightly larger milli-size.
#7 | |
frugal-phile(tm)
Now the issue is actually getting your hands on any of those drivers. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Hi planet10, thanks.
I didn't see any 3.5 litre with FE127. where is that? the only one I have seen is at lautsprechershop.de, under the fostex fe127e picture. Literally: recommended cabinet 1: closed cabinet with 3,5 L volume from 129/81 Hz (-3dB/-8dB) It's a hard decision... the only sure thing is that I'm going to use a tripath amp TA2020 Amp6 basic from 41hz or Charlize. Now I'm also considering the small Tang Band's W3 871S and HiVi B3s in small sealed boxes. Looking for som info and comparisons between them and compared with Fostex's, seems that fostex has a better quality (they say hi-endish) but it laks in the low freq's. May be it would be better a TB or HIVI for desktop PC use rather than Fostex... I've heard fostex, but in big size (FE207E), but not the small ones. anyway, thanks very much for your comments and help. |
#9 | |
What Dave was saying is that (now based on the big " if you can obtain any of the following"..) assessing from our builds with Fostex drivers, the FF85K is the performance champ in less than 4liters (vented), with the FE127 taking over between 4-13 liters. Indeed, the FF85K does some things in the upper midrange/top that can embarrass many far more exotic and costly mid / tweeters. Of course if your application doesn't limit enclosure dimensions / required operating space, or budget is open ended, the choices can be overwhelming. While the original thread topic was specific to smaller Fostex drivers, since you mentioned possible alternatives, one brand that hasn't yet been discussed at length here and that many DIYers have been very happy with are the latest offerings from Mark Audio. While lacking the sensitivity of Fostex drivers, for your intended application and available power, the CHR70 (metal cone) or EL70 (paper) would be well worth consideration.
#10 | |
frugal-phile(tm)
My notoriously bad typing skills strike again. Should be 4.5 litre. All the milliSize boxes are based on that volume.
I am just now working on a smallish sealed box for a set of treated TB W3-871 (~2,5-3 litre), we'll see how that works out. dave
| FE107 options-Metronome? | bobhowell | Full Range | 10 | 13th April 2009 01:46 PM |
| fe87e Superbowls | Juspur | Full Range | 23 | 5th February 2009 07:04 AM |
| 'off the shelf' FE87E BLH | bibster | Full Range | 3 | 16th June 2006 07:06 AM |
| Crossover recomendations/enclosure for SEAS W15CH001 and Hiquphon OWI? | Guijs | Multi-Way | 16 | 9th June 2006 06:33 PM |
| FE87E Graphs | philipbarrett | Full Range | 3 | 22nd November 2005 10:03 PM |
| Page generated in 0.14918 seconds (82.33% PHP - 17.67% MySQL) with 11 queries |
