Old 17th June 2010, 06:39 PM   #1
Default FE206E and surround ?
I'm getting close to finishing a pair of Fostex recommended horns for a couple of 206e's . Has anyone used these speakers as mains in a surround system along with the FE107E in the BR box for center and rear channels?
I've got consumer Polk monitors right now and just think a fostex based system would have to sound better.
Thanks for any feedback.
Old 17th June 2010, 08:40 PM   #2
Send a message via ICQ to Crossblade Send a message via AIM to Crossblade Send a message via MSN to Crossblade Send a message via Yahoo to Crossblade
I have 206eN in the 208eZ Sigma box for my stereo and surround front. I had a couple of FE87e for center but now are used for the L/R surround and use a virtual center (it is almost excellent if you are in the sweet spot). I am very pleased with the result. Get a decent subwoofer!
Old 20th June 2010, 12:24 PM   #3
Thanks Cross, I'll look at the 87s.
I've got a 4x12" T/L sub that I'm pretty happy with.
So you like the 206 driver in the 208 horn?
Later
Old 20th June 2010, 02:35 PM   #4
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
FE87E are no longer available now. Actually Fostex decided to cease production of the FE magnetically shielded models and the whole FF line. However, there's no replacement for both. I'm not sure if that's because of the fact that Japan is in deep financial trouble.
Old 20th June 2010, 04:01 PM   #5
frugal-phile(tm)
planet10's Avatar
The FE206e recommended horn is not amongst their best work... 208 horn is usually recommended as a better bet for the 206e.
I haven't looked too closely at them but the new FE83En should be a reasonable sub. It is hard to make a 3" driver with a really low Q, so should be suited to BR, matter of fact there is another thread right now about them.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th June 2010, 06:24 PM   #6
Kripes you mean I gotta build another set of horns?
thanks for the heads up Dave, I'll wander over to the 83En thread and read for a while. I had seen some talk about the 208 box being better-but just put my faith in the factory guys. I'll print off the 208 plans and start procrastinating right away.
thanks borispm, makes you go Hmmmm
Regie
Old 20th June 2010, 11:19 PM   #7
frugal-phile(tm)
planet10's Avatar
The factory doesn't have a very good track record. Lots better than any of the fostex factory horns.
dave
Old 21st June 2010, 12:42 PM   #8
dave
I know this is a loaded question but, which horn would you recomend Dave? I had seriously looked at the Sachiko double horn-I have no WAF to worry about, so I'm able to consider all candidates.
Cool job you have Dave, I enjoy what I do but it's just a job. Thanks for your help and knowledge.
Regie
Old 21st June 2010, 02:20 PM   #9
chrisb is offline chrisb  Canada
Regie
Ron Clarke's Dallas?
http://homepage.mac.com/tlinespeaker...asII-plans.pdf
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 21st June 2010, 03:32 PM   #10
wow the last set of plans I wanted to tackle, I can build fairly well, but those will be a challenge for me.
Thanks Dave and Chris, I didn't intend for this thread to turn into a discussion of old news. Thanks to all for putting up with blind folks plodding along.
I will finish the cabs I have and look forward to an upgrade in the future, based on better info.
Thanks again
axial surround instead of radial surround Calvin Subwoofers 22 13th July 2009 06:46 PM
FE206e Question toen Full Range 19 11th November 2007 10:56 AM
Tweak for the FE206E usa_satriani Full Range 15 27th April 2006 10:52 PM
FE206E or FE168EZ? congari Full Range 13 9th November 2005 06:23 PM
fostes fe206e gonzii Full Range 4 31st July 2005 08:33 AM
Page generated in 0.10180 seconds (78.61% PHP - 21.39% MySQL) with 10 queries
