doped cloth surround?
Old 1st January 2018, 11:55 PM   #11
phivates is offline phivates  United States
I was addressing the OP
Old 3rd January 2018, 10:40 AM   #12
turk 182 is offline turk 182  Canada
to the OP try this Speaker Repair Latex Adhesive - Professional Grade for Surrounds Cones Dust Caps and more.
as to fabric types for cloth surrounds there are so many types with varying characteristics that that is ultimately up to the end user.
on the cheap if you need to re-seal a cloth surround glycerine can be used.
note: neither of these have any documented benefits for motional feedback experiments
Old 4th January 2018, 09:05 AM   #13
MrBoat is offline MrBoat  United States
Liquid EPDM Rubber. Some of which is used by the roofing trade. Possibly research what solvent base it is and thin it accordingly. Linen would make a suitable surround. Ideally a die could be made to shape the accordion feature, perhaps with plastic spline cord that could be rolled into the grooves until the rubber set up like when rescreening a window.
Old 6th January 2018, 10:05 PM   #14
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by LineArray View Post
If your cone is paper and the cloth is cotton based
white wood glue can be used (maybe dilluted) to glue the cloth
to the cone.
Exactly that is what i have had to do with about 80% of the FE103A i pulled from Admirals Tunnel Reflex boxes.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th January 2018, 08:11 PM   #15
MikeV is offline MikeV  United States
Hi Dave!
Happy New year!
So glad that you've brought this up!
How (in your opinion) does the once much vaunted FE103A stand up in 2018?
Is there an optimal box for this aged beauty?
I've go t a pair in TQWP that I enjoy, and have been wondering whether to go next to a Karlsonator or perhaps a Frugelhorn.
Your thoughts? TIA
Old 8th January 2018, 01:43 AM   #16
frugal-phile(tm)
planet10's Avatar
Modern drivers keep getting better and there are a lot more of them.
That doe snot detract from the FE103A, especially if you score a $4-10 set of Tunnel Reflexes. But it has pushed their maximum worth down.
dave
Old 13th January 2018, 04:21 PM   #17
Default apologies for the Hi-jack...
Thanks for the reply, Dave, and thanks for your expertise with our Full Range eccentricisies(sp)
Back to my FE103A's...
1) should I move on to something in the 21st century? <grin>
2) what other cabs best suit the FE103A?
mini Karlsonator? Zigmahornet? Frugelhorn?
I'm not unhappy with my TQWP, but I can't help but wonder if there isn't something else to be had.....do you have any thoughts on Bert Doppenbergs variant? (I've collected a few pair of the FE103A)
Thanks Dave for your insights!
All the Best,
Mike
Old 13th January 2018, 06:30 PM   #18
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3, & Aiko are proven good (Aiko the best we’ve heard). They would probably also do well in Vampyr-V. It is also possible a pair could be used in the miniTower (the casle version is preferred by builders), and maybe a variation of the big Woden BVRs.
Because the T/S can be quite variable due to aging one of the horns (were the box dominates) is the better bet. If you weant to use 2, perhaps the double FH3 (drivers wired in series, one with a big cap shunting it).
Bert’s double ML-V is OK, but was done before good modelers came out.
dave
Old 15th January 2018, 04:02 PM   #19
Default Thank You!
Woo Hoo!!
Lot's to digest!
Thanks for your time and for sharing your Knowledge!@
I'll ruminate on this great info and move forward with a prototype!!!
Thank you Sir!!
doped cloth surround?Hide this!Advertise here!
axial surround instead of radial surround Calvin Subwoofers 22 13th July 2009 06:46 PM
FS: pair Wharfedale 15 inch -W/15/CS(Cloth Surround- 1955/56) $100 MichaelPublic Swap Meet 3 10th June 2009 06:49 AM
Do drivers with cloth surround sound boxy? goldyrathore Multi-Way 1 4th November 2008 09:04 AM
Renewing cloth surround ktuuri Full Range 9 12th September 2008 09:17 AM
