Took apart and tossed the old TV at the cottage, pulled these guys out've 'em. I flipped through the Wich driver is the "real" Fe103a?? thread and didn't see a match for my basket.
Curious about what these guys are. The dustcover in the middle is plastic from the looks of it. Hmm... The markings on both drivers read as follows; Code:
SANYO V1552A S12K50 4ohm 5W JAPAN k0Id Knock knock, planet10? Last edited by thefragger; 15th June 2010 at 05:33 PM. |
#2 |
who's there?
between the 2 annular rings on near the cone perimeter, thick pressed paper mounting gasket (they were presumably rear mounted?) and the wider profile plastic dust cap, these would appear to be significantly different from what we've casually referred to as "Fe103a" that said, there's no reason they couldn't sound fine within limited application
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 |
frugal-phile(tm)
These are an interesting driver. Not in the FE103A family, largely due to the fact that they are not alnico. They have a ceramic magnet on what is normally an alnico motor. A good illustration of how potent alnico is, the much larger piece of ceramic probably still lags the alnico that would have been in the same driver on some earlier run.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
I guess I should learn about how to measure drivers, and then measure these ones, before I can build a box, eh?
#5 |
frugal-phile(tm)
yes.
dave
#6 |
An AC ammeter can tell you the resonant frequency.
Connect it in series with the driver, when the current flow is lowest (ie, resistance is highest), that's where the resonance is. There's a signal generator on winISD that can help... Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#7 |
The urge to build is strong in this one............do you feel the force?
They look a lot better than the old car speakers I'm fooling around with.
Tubes and Martin Logan's |
#8 | ||
I've got a bench-top sig gen--that should do the trick, eh? So once I've found the resonant frequency I build a box tuned for that freq and I should be good you figure? Quote:
| Newbie question for UK full rangers | essjay | Full Range | 5 | 7th March 2010 11:45 AM |
| French Full-rangers | elac310 | Full Range | 15 | 22nd May 2009 06:27 AM |
| first set of full rangers done | rtenyes | Full Range | 6 | 23rd July 2007 11:22 AM |
| Lines of 5.25" full rangers? | Kensai | Full Range | 5 | 18th July 2006 09:03 PM |
| OB near full rangers... | Nanook | Full Range | 0 | 20th February 2005 08:02 AM |
| Page generated in 0.08475 seconds (84.91% PHP - 15.09% MySQL) with 10 queries |
