Old 7th June 2010, 08:33 PM   #1
Default Frugal Horns - can't decide / need help
while searching for a new project starting in October/November this year I found the Frugal Horn Speakers. I've read a lot about those during the last 2 weeks, but at the moment I can't decide which one would suit me best (to my needs). I have not heard/built a horn speaker yet (just transmissionline, BR, CB) but from what I have read so far during the last 2 weeks I think a medium sized horn could fit perfectly.
So what do I want? What must the new speaker do good? I'll try to explain:
- good dynamic range
- no ultra deep bass (50-60hz are enough for me)
- a clean sound with app. 90-95db (can't hear louder since I live in an apartment)
- while listening at moderate volumes it should also sound great (nothing must be absent)
- the new speakers should do well especially with rock/metal music --> fun!, but also other stuff shouldn't sound cra**y
My room is approx. 25m² large, the speakers would stand 2m apart, main listening position between 2-3m
So my questions to some experienced horn speaker owners (maybe even some Frugal horns)
- could they suit my needs?
- would they "fit" into my room? ("Sachiko" is to big, I already figured that out^^)
Right now I tend to the "Chang" (Fostex E207e), the "Hiro" (Fostex E206e) or the "Mikasa" (Fostex E126en).
I hope you guys can give me some help deciding...
Old 8th June 2010, 05:45 PM   #2
Originally Posted by YangMimpi View Post
- the new speakers should do well especially with rock/metal music...
Hi YangMimpi, in my extremely limited experience:
I would not expect a single-driver speaker to do metal. It might do some (less demanding) rock. If you want to use a fullranger, and do rock/metal, you might consider using it from 200hz up, mated to a woofer.
Old 8th June 2010, 06:20 PM   #3
chrisb is offline chrisb  Canada
YangMimpi:
Mr Bond speaks the truth, and there would be more than a few ways to achieve serviceable results; in a room your size the total footprint you can accommodate for the enclosures would be a big factor.
One very popular approach at the moment that costs very little in terms of construction materials would be a small OB - but the required space behind and to either side of the panel could be an issue.
Another would be something like a member of the Half Chang Family (personally, I've build a couple of pairs of Brynn with great results), with a small powered woofer per side, actively XO'd between 120-250. With a proper HP to the wideband part of the system, you can benefit from substantial increase in overall SPL, dynamic range, and reduced distortion in mids to HF range,
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 8th June 2010, 06:37 PM   #4
frugal-phile(tm)
planet10's Avatar
Hiro uses FE166e, and requires the same room size as Sachiko. Mikasa is a bit less demanding of listening distance, being shorter with a different mouth profile.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th June 2010, 07:13 PM   #5
Thanks guys for this first feedback...
Obviously, the Sachiko as well as the Hiro seem to big for my room. I just measured around some more... the maximum listening position would be 3 meters from the speakers (going further back I would end up in the kitchen )
The Maximum footprint for each cabinet shouldn't exceed (30 (width x 60 depth) cm wenn placed directly in fornt of the wall (an estimated depth of 40cm would result in an 20cm space to the backwalls. A couple of centimeters more or less are no obstacle.
Maybe I should explain why I wrote "espacially for metal". I'm still very happy with the Needles - I really like their tonality, also while playing metal (I do NOT listen very loud at all). What I wanted to achieve with the new speakers is: more "in your face" (more dynamic) but still a quite linear reproduction from 60 hz upwards. I little dominance of the mids is no problem at all for me, since I like that. I know all horns go well louder than the Needles, but I think I'll never listen to them louder than 90db. So max volume and frequencies below 60hz are not important to me.
With that additional information given - any further suggestions from you?
PS: Of course the Hiro made for the 166,167,168 driver and not for the 206e ... it was quite late last night when I wrote that
Old 8th June 2010, 07:16 PM   #6
frugal-phile(tm)
planet10's Avatar
What kind of amplifier are you using?
dave
Old 8th June 2010, 07:22 PM   #7
Right now I am using a Dual CR 1730 Stereo Receiver.. nothing fancy. 2x25W with a sound tending to a slight warmth.
But I am also looking out for something new - a vintage Marantz Receiver maybe - or something "british" from the 90's - Rotel, NAD etc.. but thats secondary at this moment
Old 8th June 2010, 07:30 PM   #8
I just took a closer look at the suggested Brynn. Kind of like that speaker, too... the only thing I worry about is the height of the speaker itself... it's about 62cm, with spikes/stands 65mx... thats about 25-30cm lower than my ears at listening position.
Must I be worried about Sweetspot or "listening off-the axis" problems?
Old 8th June 2010, 07:32 PM   #9
frugal-phile(tm)
planet10's Avatar
If you are looking to a high damping factor amplifier, and with even as much power as you have now, i would suggest looking at one of the Lake District or British Auto Series. Lotus, Coniston (or better yet the ^2 versions). Steven (Italyion Stallion) has built both.
dave
Old 8th June 2010, 07:39 PM   #10
frugal-phile(tm)
planet10's Avatar
Brynn limits you to finding some FE127e (i still have FE127eN available), but coming up with similar for EL70 & CHR70 based on Mar-Kel, and Mar-Ken is something Scott & i have touched on.
We had no issues with the height of Brynn (i have a set here), but some tilt-back pretty much cures any issues.
dave
Frugal-Horns Sachiko 8" horn speaker - Nasty dips in frequency response jmillerdoc Full Range 117 4th June 2010 04:23 PM
looking for opinions on frugal horns with the veravox5s vs. fostex fe126/108ez mp9 Full Range 1 28th October 2006 07:47 AM
Page generated in 0.12748 seconds (78.79% PHP - 21.21% MySQL) with 11 queries
