Fostex FF85K in the Buschhorn Mk I?
Old 6th June 2010, 10:16 PM   #1
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Default Fostex FF85K in the Buschhorn Mk I?
Has anyone ever tried putting the Fostex FF85K in the Buschhorn Mk I enclosure? It looks like a relatively easy build, and the FF85K seems to be approximately the right size. The plans for the enclosure can be found here:
Mini-Basshorn mit VISATON FRS 8
Old 6th June 2010, 10:20 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Worth a shot... but if you are interested i have 2 different upreleased Spawn horns for the FF85 that it wouldn't hurt having proto-typed. email if interested.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th June 2010, 11:18 PM   #3
delsix is offline delsix  United Kingdom
Hi, any chance of a copy of the plans. Email sent
Old 26th June 2010, 01:48 AM   #4
Ty_Bower's Avatar
It appears I've gone and cut a bunch of plywood into strips. When I chop the pieces to length on the mitre saw, is it important to try to make some of the smaller angles? For example, pieces E, F and G all have angles of less than one degree. I don't think I can cut that with any kind of accuracy on my saw. The 10.6 degree acute angle at the end of L seems like it will be tricky, too.
Click the image to open in full size. Click the image to open in full size.
http://i69.photobucket.com/albums/i4...n/P1140013.jpg
http://i69.photobucket.com/albums/i4...hhornMkIv6.gif
Old 26th June 2010, 01:56 AM   #5
frugal-phile(tm)
planet10's Avatar
You'd need a tenon Jig to cut that angle... or do an Ed Schilling.
dave
Old 26th June 2010, 02:29 AM   #6
Ty_Bower's Avatar
Is this a tenon jig?
Miter Saw Acute Angle Jig - bricofleur - American Woodworker
Old 26th June 2010, 02:47 AM   #7
frugal-phile(tm)
planet10's Avatar
That would be the equivilant for a mitre-saw. I think a tenon jig is for a table saw.
dave
Old 27th June 2010, 02:31 AM   #8
chrisb is offline chrisb
dave
for a quick and safe method of cutting the bevels for the angled deflectors I'd use Delta/Porter Cable 34-184 tenoning jig (let google be your friend and take you to a review / tutorial on this great little gadget.)
OnlineToolReviews.com - Delta 34-184 Universal Tenoning Jig Review
while this tool is designed to firmly hold the workpiece at 90deg to the table saw top, there's no reason the blade can't be tilted
of course for you could build a wooden jig to accomplish the same purpose, but there are some tools on which it just pay to splurge (particularly if you can amortize the expense over hundreds of pairs
anyway, in this case you set the bevel cut on your table saw to the more obtuse angle needed on the deflector (30deg on the saw's bevel gauge), and make the first cut the "normal" way, then leaving the bevel angle, install the workpiece in the tenoning jig and cut the acute angle.
Even if the blade setting is off a bit, you'll get a perfect fit between the front and bottom panels of the cabinet
Old 27th June 2010, 03:35 AM   #9
Bigun is offline Bigun  Canada
Bigun's Avatar
speaking as a man who only has access to hand tools, including a circular saw, I find that a hand-plane plus a wooden block and some sandpaper allows a high degree of fine tuning when it comes to this kind of stuff !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th June 2010, 02:41 PM   #10
Ty_Bower's Avatar
Silly question... a web search turns up far more results for the Buschhorn MkII, and relatively few results for the original Buschhorn design. Any thoughts as to why the MkII is much more popular?
Fostex FF85K in the Buschhorn Mk I?Hide this!Advertise here!
Playing around with Fostex FF85K Leffler Full Range 18 18th January 2013 07:15 PM
fostex ff85k as a mid-hi in 2 way speaker mipop35 Multi-Way 0 1st December 2008 05:13 AM
Fostex FF85K for sale lcholke Swap Meet 3 14th September 2008 06:01 PM
amp for Fostex FF85k tame Multi-Way 0 28th February 2005 07:21 PM
fostex FW208N and FF85K navin Full Range 26 6th June 2004 06:27 PM
Copyright ©1999-2017 diyAudio
