Old 30th May 2010, 03:54 PM   #1
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Default Any Chance that an OB/back loading horn hybrid will work?
The diagram says it all, but will this actually work? I am curious about it after thinking about it for a night.
Old 30th May 2010, 04:16 PM   #2
borispm's Avatar
Sorry for my bad English illustration and the " technical notes" that is not really technically correct.
Old 30th May 2010, 04:26 PM   #3
mp9 is offline mp9
Open baffle is when the driver is mounted with nothing interfering with the back side of the driver and it's rear wave. If the back of the driver is enclosed in a horn compression chamber as it would have to be to function as a BLH and how it looks to be in the illustration, it can't be a open baffle. No matter how narrow the horn path the driver is still enclosed. What you drew looks like a large supra baffle, that's all.
Old 30th May 2010, 04:39 PM   #4
Speakerholic
Cal Weldon's Avatar
Yes provided the horn length is long enough and mouth is wide enough it will work. That might mean making it taller than shown.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st May 2010, 12:04 AM   #5
Horn action depends on pressure.
Old 31st May 2010, 09:11 AM   #6
borispm's Avatar
@mp9
Sorry for my bad naming, it shouldn't be called a real OB but a leaky horn (oh, this name reminds me of those leaky dripping sewage pipe...err).
Maybe my illustration is bad, the driver is not fully enclosed to the horn mouth, so that's not an oversized baffle on a horn.
@Cal
The Vifa has a F0 of about 115Hz so I assume something like 1.2m will work good enough as I hate muddy and one-note bass. Please let me know if I am wrong about this.
What I worry is that my design features a leaky horn, only a proportion of the rear radiating wave joins the horn chamber, and will that be a problem?
The horn mouth is on the narrow side (about 1"), and I dunno if that's a good thing...
Old 1st June 2010, 01:11 AM   #7
if the decaware zen OB + tuned chamber is working, then no reason this will 'work' in some way... it will for sure affect the sound somehow
Old 1st June 2010, 01:22 AM   #8
BudP is offline BudP  United States
BudP's Avatar
You could just have a set of plates running back from the driver, the width of the entire driver and have a tall, narrow,deep, open ended box, with hanging stuffing and a long enough path length to provide a cardioid bass box. You might even provide a horn flare within those side plates to help smooth the loading.
Putting foam on the back of the driver to attempt to seal a portion of the cone surface to the horn might work, if you EnABL the driver to rid it of spurious patterns of front wave mission. I don't think you will get much benefit doing this until you have some decent amount of cone surface to work with. Intriguing idea though.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 1st June 2010, 01:32 AM   #9
GM is offline GM  United States
GM's Avatar
Not if the horn's design takes it into consideration, i.e the horn is under-damped enough to need a leak to bleed off its excess 'boom'. It's a common way to match a high Q driver to a horn designed for a low Q one.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st June 2010, 02:14 AM   #10
borispm's Avatar
Thanks for your replies, gentlemen. However, can Mr. Human.bin tell me more about the decaware thing? I haven't seen it before...
Re GM
Is my shorter than normal horn itself already suitable for high Q drivers? If I follow what Fostex usually do I should have made it 1.4m instead of 1.2m... In this case, will it be better for me to make it 1.4m as it is a leaky one?
The Vifa TG9FD10-04 is used in this case, which has a relatively high Qts (0.73).
Front & rear end DUAL Back Loaded Horn + Bass Reflex Hybrid Enclosure nickthevoice Multi-Way 13 19th May 2009 03:09 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Help with horn loading Web Wolf Multi-Way 3 25th October 2006 06:38 PM
Isobaric loading, would this setup work??? swin1 Multi-Way 3 20th May 2006 03:58 PM
Not sure how to make a front/back loaded horn work ? audioaction Full Range 9 1st April 2006 06:59 PM
Page generated in 0.10373 seconds (78.83% PHP - 21.17% MySQL) with 11 queries
