I build a couple of months ago a set of semi-frugels for my wife's practice.(pic.1 and pic.2)
I decided on some measurements. Used system : asus eee pc XP and ATB701pc. condition : Iplaced both the speakers in a corner ; mouth 50 cm and 50cm from the wall and the door in the corner. I took measurement with "open "door and "closed" door (= corner loaded.) for both speakers. all conditions are the same for ATB, placement (tape on the floor) and amplification. You can clearly see : 1 1kHz "hole "for the fe108ez. 2 The 7kHz peak for the fe126e. overall efficientie is higher for the 126 but the bass is almost the same so the IBR108 gives relatively more bass. Open for discussion ??
Leon |
#2 |
Jpeg's.
Leon |
#3 |
ibR108 vs frugel126
Unfortunatelly I didn't took the oppertunity to change the collor for the second speaker; do your best!!
Leon |
#4 |
Hi Leonidas,
Which one do you think sounds the best to you ? The 108 EZ seems like it would sound more relaxed. PJN |
#5 |
Do you hear the bass bump as intrusive on the music?
#6 |
My wife heard them, side by side, and she wants a pair of ibR108's.
She has a reflexology practice and needs detailed and at the same time relaxes music.( new age stuf ) The 108 , in the right constuction, is worth the money. I'm working on a fronthorn to deal with the 108 "hole" , that's why I took measurements. Dave (planet10) does things with the stock 126 to improve them. Hard to get in the Netherlands, so difficult to compare for me.
Leon |
#7 |
Hi Godzilla,
No you don't hear it at all, I forgot to close the door of a second room wich resonates at 50Hz. (I never listen music in there; think about tube sound hum!!)
Leon |
#8 | |
frugal-phile(tm)
Thanx for posting those, Leonidas. Stock FE126e is definitely more fatiguing that FE108eS.
I have yet to revist the ibR108 plans since i got your comments back. I'll keep you in the loop. dave PS: with ATB you can generate proper waterfall plots (time axis in periods). I'd be really interested in seeing some of those. Is it also possible to display an ATB waterfall looking into the time axis? (ie a 2D chart)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
P-10,
Work is very busy at the moment. But I will certainly do more measurements later on. I already was glad that I could show this ones!! I'm still studying the ATB set. I was working with a DAAS 32+ system before this one (on an ISA slot) so everything is new to me. As soon as I have a little more time I will share everything with you. Speakers in your interest wil be : FE207E , FE166E , FE126E and FE108ez and the Lowther dx3. I also saw in the books that the ATB701pc has an export function!! Have'nt found anything yet about rotating the axes of diagrams, but who knows? warm greetings
Leon |
| Measurement microphone | Web Wolf | Multi-Way | 11 | 7th May 2006 07:15 AM |
| Need some measurement help | mazeroth | Multi-Way | 5 | 24th April 2006 07:22 PM |
| how do you do a measurement? | aarono | Multi-Way | 0 | 12th April 2005 01:50 PM |
| which measurement software?? | steverb | Multi-Way | 19 | 27th October 2004 06:08 AM |
| distortion measurement | djdamix | Solid State | 1 | 20th August 2004 07:11 AM |
| Page generated in 0.10376 seconds (74.79% PHP - 25.21% MySQL) with 11 queries |
