Old 22nd May 2010, 02:20 AM   #1
Default Downloadable blh calculation software.
I am looking for a good back loaded horn software that i can
get on the net (not nescesarely free).
I'd like to build a good, deep bass Fe208 blh.
Thanks guys!.
Old 22nd May 2010, 02:41 AM   #2
frugal-phile(tm)
planet10's Avatar
Martin King's mathcad worksheets.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd May 2010, 05:10 AM   #3
1. Quarter Wavelength Loudspeaker Design
2. Telstra BigBlog -
3. AJ-Systems
Old 23rd May 2010, 11:48 PM   #4
Martin King's seems like a complex affair... Is it a calculating
software or spreadsheats that you got to calculate yourself???.
Thanks guys
Old 24th May 2010, 12:03 AM   #5
frugal-phile(tm)
planet10's Avatar
It is a set of worksheets you run in MathCad (free demo version is available). The UI is not what you call slick, but it is more capable than anything else out there (IMHO) with the exception of AkaBak (and it is really a programming language)
dave
Old 24th May 2010, 01:33 AM   #6
Martin King's software is designed to be used by anybody, and it's pretty much a "fill in the blanks" process. It doesn't design the box but it's very easy to get started.
For a TL, you just need to worry about the driver parameters, and the box's area and length "above" the driver (closed end), and "below" the driver (open end). Even the OB and BLH models are pretty easy to use.
It does get more advanced if you want to model the in-room response. You specify the distance to each wall, how many degrees the box is rotated etc. But you can ignore those parts until you're interested in them.
I don't understand any of the math and physics, and luckily, it's not necessary. You can always ask questions on MJK's Yahoo group. It's very newb-friendly (I am one of the newbs).
Old 24th May 2010, 09:03 AM   #7
markusA is offline markusA  Sweden
MJK's spreadsheets are very nice and once you get the hang of it not at all difficult.
The single most frustrating aspect is imho deciding when enough is enough. What simulation is likely to result in the best sounding speaker?
Old 24th May 2010, 06:27 PM   #8
Thanks a lot guys! i'll look into that soon!.
My software for calculation Thiele/Small for unknown speakers DigiSoft Multi-Way 14 5th May 2010 05:32 AM
Transformer calculation software? bentl Planars & Exotics 2 5th May 2009 09:06 AM
Where to buy downloadable bit perfect software ? mikelm Digital Line Level 5 15th April 2009 09:18 PM
Stepped attenuator resistor calculation software pmillett Tubes / Valves 0 1st May 2008 05:05 PM
Cap, Res, Ind Circut Calculation Software Allan Multi-Way 0 26th March 2004 09:28 PM
Page generated in 0.11656 seconds (73.03% PHP - 26.97% MySQL) with 10 queries
