Old 21st May 2010, 10:10 PM   #1
Default alpair 6 with woofer
I have an alpair 6 full range that I want to crossover with a woofer, what crossover should I use.
I am a noob so please be as specific as possible.
It will be in a modified horn speaker, and powered by a dynaco st 70.
Old 21st May 2010, 10:41 PM   #2
tinitus is offline tinitus  Europe
Details on woofer needed
Old 21st May 2010, 10:56 PM   #3
Default woofer
hi,
the woofer is Peerless vline woofer. Smooth, extended response with low distortion. Truncated polymer frame with chamfered edge simplifies installation. Magnetically shielded. Buyout, limited quantities. Specifications: *Power handling: 60 watts RMS/120 watts max *VCdia: 1" *Le: 0.76 mH *Impedance: 8 ohms *Re: 5.56 ohms *Frequency response: 60-5,800 Hz *Fs: 60 Hz *SPL: 89 dB 1W/1m *Vas: 0.40 cu. ft. *Qms: 3.03 *Qes: 0.51 *Qts: 0.44 *Xmax: 3 mm *Dimensions: A: 5-7/8", 5-1/16" across flats, B: 4-3/8", C: 3"
thanks, bob
Old 22nd May 2010, 12:13 AM   #4
Fs 60hz sure about that thats more like a midrange driver
Old 22nd May 2010, 02:32 AM   #5
frugal-phile(tm)
planet10's Avatar
Still, relieving the bottom on the A6 will improve mids, allow the system to play louder and give more dynamics.
Do a search on FAST systems, there are a number of threads. Here is one.
A early visualization of our next one. Baffle on mid-tweeter unit will be changable so we can try FF85/CHR70/EL70/A6/A7 etc.
I also have a much simplier head unit for A5 in the works.
Do you want to do passive XO (1 amp) or active (2 amps)?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd May 2010, 11:57 AM   #6
Default alpair 6
I want to do a passive crossover with one amp a dynaco stereo 70.
Old 22nd May 2010, 01:41 PM   #7
Ok, if you already have those woofers, they will do fine for the important BSC compensation (100-300hz)
More info on the modified horn you mentioned ?
Old 22nd May 2010, 05:19 PM   #8
You could make a "shoe" on that, like Canon uses on their cameras. Then you could swap out heads to match whatever mood you're in. A lot more work building extra head cabinets, but the switch time would be less than a minute. Of course, I also looked at that and thought "robot body w/ command module." I think I need some more coffee.
Old 22nd May 2010, 06:32 PM   #9
frugal-phile(tm)
planet10's Avatar
Exactly. We will probably only build one set of the complex head units, but Chris has sourced a bracket system that will let us swap them... the idea is to consider creativity and promote the EL166 woofer unit (MA $6 woofer) ... the A5 head unit will be made of PVC pipe (the critical part is already done). One could just extend the top of the box to make an attached head unit, to get a monkey coffin, fix 1 IKEA blanda bowl to a pice of PVC or carboard tube, make a simple rectangular based box, or <insert imaginative idea here>
dave
Old 22nd May 2010, 06:35 PM   #10
frugal-phile(tm)
planet10's Avatar
Woofer needs to be more efficient than the A6 (not hard) and you'll want to XO near the baffle step frequency. You won't want too wide a box, or the passive component values needed will get too large to be practical.
The illustrated box will be passively XOed, box width indicating an XO in the 300 Hz region. Prototyping will be done with a (modified) DCX2496.
dave
Alpair-10 with Alpair 5, German combo markaudio Full Range 17 7th November 2010 11:58 PM
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 11:48 AM
Alpair 7 - out of the bag markaudio Full Range 16 27th November 2009 12:30 PM
Need woofer advice for Alpair 50 wide range build tybox2000 Multi-Way 3 24th November 2009 06:25 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 11:37 AM
Page generated in 0.10276 seconds (80.26% PHP - 19.74% MySQL) with 10 queries
