Old 10th May 2010, 07:35 PM   #1
Martin Prothero's Avatar
Default Driver on the blink?
I may be being paranoid but I can notice on some tracks that my left driver is distorting at certain frequencies.
Fostex (FE168EZ) bought about 3 years ago. Has had lots of use but never abused. How long is the life expectancy for these?
It may be an amp issue. I have just finished a gainclone (stereo LM3875). I have swapped over the speaker cables at the amp end and it seemed that the right driver was not showing the same symptoms.
The sound is a grainy slightly fuzzy sound, just audible in some music (like cleanly recorded sax or clarinet). I thought it was just the sound of the reed at first but with my head really close I can defo hear something odd going on...
Any thoughts? Could it be DC on the left amp channel?
Keep a green bough in your heart, the singing bird will come.
Old 10th May 2010, 07:42 PM   #2
Speakerholic
Cal Weldon's Avatar
Try another speaker to see if it's the amp. If it is the Fostex, try removing and turning it over. It may be a rubbing coil and this may fix it.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th May 2010, 07:45 PM   #3
frugal-phile(tm)
planet10's Avatar
I would at least take a precautionary look for DC. I'd also check to see if some damping material has come in contact with the cone.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th May 2010, 08:01 PM   #4
Thanks guys. I'll have it out tomorrow and look for any of the above signs.
I measure DC at the speaker posts right, or will it need to be at some other part of the amp output?
Old 10th May 2010, 08:03 PM   #5
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Yep, at the outputs.
Jim J.
Old 10th May 2010, 09:23 PM   #6
Erm
Be gentle on me...but I seem to be getting some odd readings so I am obviously not understanding this right.
I have set up my DMM with crock clips on the outputs of L speaker posts and have music running through it. I wanted to measure at 0 and full volume but the readings are fluctuating with the music.
Do I need to find a sine wave and use that? Maybe my DMM isn't set to the correct reading. (I can't find the instructions and I last read it about 3 years ago!)
Can someone be nice and treat me like a school kid and tell me what I need to do and which symbol to put the meter on.
eerm, please:-)
Old 10th May 2010, 09:29 PM   #7
godfrey is offline godfrey  South Africa
Check for DC with the amp on, but no signal. e.g. volume all the way down.
Old 10th May 2010, 09:40 PM   #8
OK.
I put the black probe (in COM on meter) onto the ground post and the red on the positive. The symbol on the meter is the V with a line and a dotted line (not the wavy one) and the measurements were
L channel: -02.4mV at zero and -46.2mV at full volume
R channel: 11.1mV at zero and -36.0mV at full
Does that make any sense to anyone or am I just slipping into a coma?
Old 11th May 2010, 10:35 AM   #9
Well, I think it was a mounting issue. Took out the driver to inspect. Nothing unusual to be seen but when I tried again having put it back in the original problem seems to have gone. Screws were all tight, so I don't have a clue!
Fingers crossed it was just a blip and will never come back.
Old 11th May 2010, 12:06 PM   #10
kipman725's Avatar
Send a message via MSN to kipman725
probobly the early mentioned rubbing voice coil and by moving the driver you reset it to the correct position. I had a driver do this seemingly randomly and unfortunatly it was unfixable, although it was 15 years old.
BGW Pro 250E on the blink DanGriffing Solid State 1 23rd September 2008 06:59 PM
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Quad 34 on blink FM300 Solid State 12 20th March 2005 08:59 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.12255 seconds (80.86% PHP - 19.14% MySQL) with 10 queries
