#81 |
FWIW, we found them very colored and "lumpy" from the lower midrange down, (indeed, the most idiosyncratic of all the smaller Fostex "recommended" designs I've heard ), and that the Buschorn MKI folding, which is easily modified to fit a 4" driver* is vastly superior in all respects.
*If you've not already seen this, page 18 of the attached PDF shows plans for modified BH MKI. We built 2 pairs for direct comparison of FE108ESigma and FE126E - the former does some very nice things in the midrange, but the latter is overall much better bang for the buck. http://homepage.mac.com/tlinespeaker...aps-130307.pdf
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#82 |
frugal-phile(tm)
If i was to redo an enclosure for that space, i'd probably go with something like mFonken103 or Solo 103 (with terminals on the front)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#83 | |
frugal-phile(tm)
dave PS: Listening to RonHorn A126 right now (but need to swap in the proto dMar-Ken7 (with Alpair 7)
#84 | |
Ron provided 2 options for the Austin A126 design, the omnipresent back firing one, and also a side firing version. Both were discussed at length at James' site, but if I remember correctly the back firing one had a revision over the side firing one. The plans sit together at the Frugel Horn site. Regards Gastón |
#85 | |
Gaston: I may be wrong, but that may well have been a thought exercise - i.e. I'm not sure of how many (if any) builds of the side firing version were executed, and/or how they might compare to the rear-firing. I can say that a slightly modified version (i.e. larger coupling chamber) of the rear firing version remains after several years now the most overall satisfying enclosure design I've yet* encountered for the FE126E. (*IOW, Scott has been a busy boy)
#86 | ||
| An unusual "feature" on a commercial amp... crosscoupling between channels at hf. | Mooly | Solid State | 1 | 1st February 2010 09:13 AM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Horn-loading the "new breed" of pro sound 6.5-8'' drivers | Swedish Chef | Multi-Way | 61 | 28th April 2006 01:01 AM |
| Data of Isophon DKT11 "Exponential-Hochtonstraler", treble horn | peranders | Multi-Way | 3 | 10th December 2002 08:13 AM |
| Page generated in 0.10846 seconds (79.08% PHP - 20.92% MySQL) with 11 queries |
