Old 27th April 2010, 02:31 AM   #1
Default FE168E-Sigma, FE166-ESR and Jordan JX92S Compared
I really like 6" Fostex because they are a bit sweeter than the 8" Fostex. Four months ago, I built a BiB for the FE166-ESR's but had been hoping for more bass (as it turns out, a switch of amp fixed that).
Eventually, into those BiB's went the Jordan JX92S and wow, what an incredible amount of bass (and treble) -- a truly fullrange driver that just totally rocked out on home theater, but I got a deal on an 8-watt Dared 2A3C which made me want to go back to higher efficiency.
As soon as I swapped in the 2A3C (with Jordans in the BiB's), I heard a lot more bass. Aha, so the driver/amp combo is why the BiB/Fostex had lacked bass. The 2A3C + Jordan + BiB's actually had too much bass to be in the corners (could be useful for those without corners).
My old stand-by's, the FE166-ESR's, always felt a tad shy in the treble, so I wondered what the 168's might be like. At the moment, the 168's are in the 166-ESR's BiB's, breaking in. (The 166's are in the Austins.)
Some observations:
The two drivers weigh roughly the same, but the 166-ESR seems to have a bigger, heavier magnet. The 166-ESR has a stamped frame (painted sapphire blue) whereas the 168 has a cast metal frame.
The 166 magnet is basically just as big as the driver cutout needs to be, whereas the 168 is slimmer but "taller". Neither have clearance problems in a BiB (nor an Austin).
The 168 with its big flange seems almost as large as an 8" Fostex, but the cone area is actually quite small for a 6" driver (unless Sd includes all those bumps -- hmm.)
What the attached pics don't show is that the 168's fancy over-under surround is mirrored in the spider -- same over-under, same symmetry. A truly unusual spider but I couldn't get a close-up photo in-focus.
One bonus: the 168 has 8 holes, but four of them line up perfectly with the 166's holes. Yay.
In the end, if I'd known the 2A3 amp would have such a dramatic effect on bass, I probably would have just stuck with the FE166-ESR's and gotten a nice Fostex tweeter. (My advice: instead of collecting lots of tiny, cheap amps like I've done, maybe invest in one good one. But if you're cash-strapped, the Miniwatt does bring up the bass lots.)
In terms of sound, the Fostex have the "family sound" (smooth, beautiful midrange). Neither has the low and high extension of the JX92S, but there is a warmth and mellow tone that is lovely, laid back and listenable. It's like the difference between electric and acoustic guitars.
Regarding which Fostex is better, I'll put one of each in the Austins and see, but I don't think there would be a clear-cut winner (who knows though?) If there's a winner, it might be the BiB's which are just an idiot-proof way to lots of good sound. They aren't nearly as smooth in the bass as the Austins, but then again, they are a really fast build, plus they have a very small footprint.
Old 27th April 2010, 02:48 AM   #2
ra7 is offline ra7  United States
Nice summary!
The jordans need a different amount of stuffing (usually a lot more) to get the bass down in a cabinet meant for a driver like fostex (read light cone, low qts).
Of course the jordans are a different kind of fun and I bet they play louder too.
I agree on the miniwatt too... its a fantastic amp for the money. I've begun to reach its power limitations tho... currently on OB, driving AN8s, the miniwatt begins to clip on loud or complex sections.
Old 27th April 2010, 05:46 AM   #3
Hi ra7,
My sense is that the Fostex and Jordans all play roughly the same in volume (the Fostex being more efficient are happy between 9 and 11 o'clock, the Jordans wanted 12 to 1 o'clock).
Two clarifications on the pictures:
1. In the side-view pic, the height difference is exaggerated because the FE168E-Sigma has its "plastic protector" on, giving another 1/8th in height. (The plastic protector prevents the driver from sitting on its surround.)
2. Oh look, you can indeed see the 168's unique spider in that side-view picture.
Old 27th April 2010, 01:57 PM   #4
Godzilla's Avatar
LOL. I agree!
I also agree. I have a nice Cary tube amp that i love. But it's fun to collect cheap amps too. My cheap digital amp collection is about to grow again.
I find this to be the case with my 168s (old style with wizzer) and 165k when they are in the right cabinet. But i find the 127e to be more forward and bright.
I always wanted to hear the Jordan's... still do.
Godzilla
Old 27th April 2010, 05:38 PM   #5
Hi guys,
Sd: 113 cm^2 (168) vs. 132.7cm^2 (166ESR)
Qts: .26 (168) vs. .21 (166ESR)
Bl: 8 Tesla (168) vs. 8.564 (166ESR)
Xmax: 1.6mm (168) vs. .7 (166ESR)
So the ESR does seem to have the stronger motor, whereas the 168's higher Qts and Xmax could have a little more bump (but only marginally, I would imagine, since its Qts is still very low). Or maybe all the differences balance out -- either way, these are both horn drivers.
I'm not sure how they calculated the 168's Sd, since it looks like an origami project (5-pointed star "recessed" into the cone, with corresponding "mountains" and "valleys".) The dust cap has the same sort of 3D design.
The paper on each driver seems different, with the 168's paper seeming coarser and drier to the touch. Based on that, I'd guess the papers are not the same formulation.
Last edited by rjbond3rd; 27th April 2010 at 05:42 PM. Reason: Changed "BL" to "Bl"
Old 27th April 2010, 06:02 PM   #6
Another difference: the factory frequency response graphs.
The FE166ESR has always sounded smooth as fresh-churned butter to me, and they sounded good right out of the box (I can't even remember breaking them in).
The FE168E-Sigma, by comparision, immediately sounded quite sibilant (but is not yet broken in). It does seem to have some bumps in the range of sibilance.
Maybe:
(a) the 166's bigger motor results in a smoother response?
(b) the 166 sounding a tad shy in treble is actually a lack of spikes in the frequency response?
It's interesting how close these drivers are, feature for feature.
Old 27th April 2010, 07:00 PM   #7
mp9 is offline mp9
How do you feel about the horn delay of the Austin/166es-r? Iirc that was the prior issue Robert had with them. Has me wondering how that aspect compares to the Hiro? So far i think Hiro's shortcoming's are listening distance's required and from what i gather here a less balanced BW.
My problem with the Austins is they'd have to be out 4' and 6' from each side wall when up along a 19'L interior wall/brick exterior. Another room could accommodate them on a 9' span on the same brick front side of the house, it's actually 12'wide x 17'l only with a 3' closet outcropping of the 12'width so not ideal. That room barley works with the Hiro's on the opposite 12'w /"drywall" interior walls. I'd have to rearrange the furniture and place the Austins on the 17' side which i'm pretty sure would lose focus of imaging at ~8 out from the 45º angle placed corner horn's supra baffle/drivers.
Sorry for going slightly sideways with your original topic and thanks for the comparison.
It's too bad Fostex didn't give the 166es-r a cast chassis. I'd like to see a Alnico version which measures as well, we can only hope...
Old 27th April 2010, 07:30 PM   #8
Hi mp9,
I honestly can't say I hear the delay. After listening to tiny boxes without much bass, all I hear is the big, full, open, airy horn bass of the Austin (and BiB). It could be that I'll hear it eventually, once I top high-five-ing myself ("Austins!")
The Austins work on the side wall if you have the deflector. In fact, I think this is preferable to being in corners with the 45-degree angle. If they have an Achilles heel for me, it's the driver height is a tad high.
Regarding Fostex releasing an Alnico 166-something: someone said the best way to predict the future is to invent it. How about we /design/ one as a group project and then get it made? I just want the Alnico to come in blocks so that I can add/subtract magnetic strength like a field coil. Maybe you've seen Atelier Rullit's work? Atelier Rullit - Klangfilm 44022 - sandwich cone pictures from news photos on webshots
Old 27th April 2010, 08:36 PM   #9
chrisb is online now chrisb  Canada
Originally Posted by rjbond3rd View Post
Hi mp9,
FWIW, if you're looking for a driver manufacturer interested in entertaining (but not financing ) a small batch lot of signature series drivers, you could always talk to Mark Fenlon -
on second thought, he'd probably try to talk you out of the Alnico or stacking magnets, as well as stamped or cast metal baskets ...
but at least he would reply - try that with Fostex
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 27th April 2010, 10:01 PM   #10
Hi Chris, cool suggestion, thank you! Are there drawbacks to Alnico aside from the fragility weakening over time?
Suggestions for FE168E Sigma bigjppop Full Range 9 27th January 2010 03:52 PM
Fostex Fe168e Sigma Jamesuk1 Full Range 1 29th May 2008 05:51 PM
Jordan JX92S Gaffer74 Full Range 11 31st May 2006 09:42 PM
Fostex FE166-esr FS jeremyg Swap Meet 2 16th August 2005 01:47 PM
fostex fe168E Sigma brian t Full Range 5 6th January 2005 10:16 PM
Page generated in 0.15155 seconds (83.47% PHP - 16.53% MySQL) with 11 queries
