Old 14th April 2010, 02:39 PM   #1
Default Lowther Opus One Model B Build Thread
I would like to show the fabrication of Lowther Opus one model B step by step. You guys may be interested.
My DIYs: Lowther Academy, Acousta 115, Opus one B; Jordan VTL JX92s; Jericho Horn with Fostex FE206, SOZ, BOSOZ, Zen Lite, V8 & V9
Old 14th April 2010, 03:56 PM   #2
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Peter please keep posting. I, for one, would love to see photos of the fabrication of your Lowther Opus one model B step by step.
Tom Scata (thetubeguy1954)
"The man that hath no music in himself nor is not moved with concord of sweet sounds is fit for treasons, stratagems and spoils."
- William Shakespeare
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
Old 15th April 2010, 03:00 PM   #3
Default Lowther Opus One model B
I have to make these big cabinets alone, withoud help. It would be impossible to turn down this heavy(about 120kg) cabinet later by myself. I install 6 rollers(costors) for each baseplate. The baseplate(18mm Th'k MDF) seems to be a little weak. Some reinforcement plates and damping materials are added under the baseplate to reduce resonant. The damping material is not shown in the photo.
Old 15th April 2010, 03:23 PM   #4
I spent a lot of time to figure out the assembly process. C clamps should be uneasy to use for this non-rectangular cabinet. I think screws and wood sticks are more useful. Two side and back panels are assemblied first. Pre-assembly by screws is absolutely a must before gluing for every panels. Top panels are routed with grooves to bound the two side panels.
Old 15th April 2010, 04:11 PM   #5
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I noticed you have a JX92S based transmission line. I have some treated JX92S drivers but don't have the proper enclosures for them. Wonder if I could try them out in your enclosure.
Hear the real thing!
Old 15th April 2010, 10:45 PM   #6
Peter,
Nice work you're doing on those cabinets. Smart thinking with the rollers too! You're not only making a nice pair of speakers, you're even a good photographer as well!
Old 16th April 2010, 12:39 AM   #7
Hi, soongsc
If you want to test whether your driver gets to work or not, you can connect an amplifier(<50W) to test this fullrange driver without an enclosure. If you want to evaluate the performance of JX92S in the VTL enclosure, I am happy to welcome you. Please email me for my address.
Old 16th April 2010, 12:57 AM   #8
Hi, the.tube.guy
I am so glad to know your are interested.
Thanks for your priceless encouragement.
Best Regards,
Old 16th April 2010, 03:18 AM   #9
soongsc's Avatar
Hi, soongsc
Thanks Peter,
I have sent you a PM.
Yes, I have done some measurements, as shown in the EnABL thread. But have never had the opportunity to listen with enclosures because this is being done on the sidelines. I have been hoping someone with existing enclosures in this neck of the woods would show up.
Old 16th April 2010, 05:14 AM   #10
Hi Peter,
I made a pair of Klipsch Eckhorns once...
You need 5 hands!!!
nics work!
The Blackmores- A Crazy Lowther build... trusound Full Range 106 26th August 2010 07:55 AM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
aikido build thread- nate Tubes / Valves 1 27th February 2009 05:01 AM
The ESL Build Thread BillH Planars & Exotics 172 8th November 2006 09:01 PM
Impressions of Lowther Opus 1 or Audiovector? tubetvr Multi-Way 1 14th June 2006 09:01 PM
Page generated in 0.11157 seconds (81.06% PHP - 18.94% MySQL) with 11 queries
