Old 12th April 2010, 12:13 PM   #1
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Default Baffle for a BiB?
I'm finishing up a BiB and have a question about mounting the driver. I've noticed that many people mount the driver on a round baffle (or someother shape) and then mount that baffle to the BiB baffle. Is this recommended and, if so, what's the reason for it? Also, should the driver then be offset rather than centered?
Thanks,
Mike
Marantz PM8003 amp, HRT Music Streamer II DAC, Squeezebox Touch, DIY Krystals
Old 12th April 2010, 04:12 PM   #2
Hi Mikje, wow what driver are you using?
The supra-baffle (or some people do wings) is optional but the purpose is to move the point of baffle step, to get the driver's forward radiation (off the front of the cone) to match up with what's coming out of the mouth, so that they both sum to a flat response.
Baffle Diffraction Step
Personally, I would say centered myself but whatever sounds best.
By the way, if you can, making the supra-baffle have a slightly convex shape might be better than a flat disk. I haven't tried that but it's on my list
Old 12th April 2010, 04:30 PM   #3
mikje's Avatar
I'm using this TangBand driver:
Tang Band W4-657SH 4" Aluminum Driver
Specifications: Power Handling: 30 watts RMS/60 watts max *VCdia: 1" *Znom: 8 ohms *Re: 6.0 ohms *Frequency range: 65-16,000 Hz *Fs: 65 Hz *SPL: 88 dB 1W/1m *Vas: .22 cu. ft. *Qms: 3.32 *Qes: .43 *Qts: .38 *Xmax: 3 mm *Dimensions: A: 4-15/16", B: 3-3/4", C: 2-7/8".
and here's the info for the BiB:
BIB- Line Length=103.573, Folded Ht= 51.787, Vb=1.313, Sm=43.803, Depth(internal)=7.871, Width(Internal)=5.565, zdriver=22.475, a-b-c=3.935
W X D X H=7.065 X 9.371 X 52.537
Cut List Per Box- Fr/Bk 7 x 52.5, Sides 8 x 52.5, Slant 5.5 x 48.5 Bottom5.5 x 8
I've got everything cut for it and the slants glued to one of the sides. I salvaged some of the wood off an OLD piano I junked a couple of years ago and that's what I'll use for the front panel/baffle. If I decide I need a supra baffle, I'll probably use some more of the paino lumber.
I built some BiBs with a pair of inexpensive MCM $14 drivers. Wow, I'm impressed. I've been using them for over a year, and I still like them quite a bit. I've had these Tang Bands in a couple of different enclosures, but haven't been thrilled with them. I figure a BiB might as well be tried.
Thanks for the info,
Mike
Old 12th April 2010, 04:32 PM   #4
frugal-phile(tm)
planet10's Avatar
They are also used when the driver is so deep that the back hits the partition before the front hits the baffle.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Supra baffle for BIB? gnugear Full Range 8 24th March 2008 06:38 PM
AJ-Horn & BiB - ar some BiB "parabolic"? freddi Full Range 3 6th April 2007 03:09 PM
two BIB questions re inner baffle and driver cutout drec Full Range 3 23rd December 2006 02:59 AM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 12 12th January 2004 03:43 AM
Page generated in 0.70836 seconds (-73.95% PHP - 173.95% MySQL) with 10 queries
