Hi guys,
I am starting with the building of the Dallas II. Any tips about the damping material in the cabinet? Cant find anything about it. Thnx! |
#2 |
frugal-phile(tm)
Should be no damping required in the horn. You'll want to play with it in the air cavity.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Thnx the air cavity is the area behind the driver right? What kind of material you sugest? thnx |
#4 |
Is this the way it should be ? Any tips?
#5 |
Looks like a good start to me for damping
If you like what you hear when your ready to fire them up (and I'm sure you will), it would be a great improvement to make another set out of Baltic Birch ply or equivalent, instead of mdf ... Dave Last edited by DaveCan; 25th April 2010 at 12:59 PM. |
#6 |
Location: Checotah, Okrahoma former home of the Okra Fest
In a post on the old Fullrange forum, the designer stated IIRC.
Put some felt in the bends, and add 1-4 Ohm series resistance to taste. This is paraphrased, of course, but he did recomend damping the outside of the 2 bends, and adding a small amount of resistance to taste. I believe he also said something about the chamber behind the driver too. If I can ever get off my A$$, I've got a pair of Dallas II's to finish too. John The forum is searchable, and that's how I found the above. I do not remember the search terms I used, sorry. I found the above when researching my build. Good looking build BTW. |
| Dallas II plans | Novacaine1968 | Full Range | 6 | 13th February 2010 12:42 PM |
| Dallas II + 208E = ? | Mr.Mekulic | Full Range | 13 | 15th December 2008 05:20 PM |
| Dallas II with AER MK1? | tocaco3 | Full Range | 9 | 16th April 2008 11:19 AM |
| Where is the Dallas II | amisdad | Full Range | 16 | 5th November 2005 04:57 PM |
| Page generated in 0.09183 seconds (72.97% PHP - 27.03% MySQL) with 11 queries |
