at this point I give up on the idea of radiusing corners, graphs, so on and so forth - in general the little Karlson sounds better on vocals and guitars than my direct radiating midrange BK20 with 1772 and its bass conveys a drum more lifelike than the blh or my Khorns. Face it - there's poor sounding speakers which make good enough graphs and there's also adherence to TS based alignments which still result in non-dynamic speakers without good resolution of the bass-lower mid region. Sheer extension without a sense of pitch or ability to reach usable spl is useless.
the FE206En / K12 combo is a bit "warm" - no contour filters should be needed. I did notice a peak - peak excursion of about 1/8" on repeating bass drums strokes. My SM70 developed trouble on its other channel so had to switch to an AlephJ clone which seems a bit more mellow. This little Karlson combo is pretty cool - maybe better than some K15 coax setups. Unfortunately I've only one Kalrsonette. I'm not sure how FE206En (stock new model) nor 1772 play in the later distributive slit K12. The old cabinet does great with period Johnny Cash and Luther Perkins one more thing, my particular Karlsonette was made of 5/8" plywood outer shell laminated with 1/8" smooth hardboard then a formica skin so the shell and wings are pretty much inert. Baffle and port panels are 1/2" plywood. crude attempt to record the speaker YouTube - "Karlsonette" 1954 twelve inch Karlson speaker with FE206En (Zoom H2)
#2 |
Are plans available?
#3 |
you're the only one so far to ask for special secret "Karlsonette" plans by special Karlsonite
(front molding lip normally forwards on reversible port panel)http://img228.imageshack.us/img228/8...sonetteib7.png |
| anyone get/analyze (stock Fostex) FE206En? | freddi | Full Range | 24 | 8th April 2010 06:00 PM |
| FE206eN and Alpha 15 in OB? | aquapiranha | Full Range | 30 | 5th November 2009 10:40 AM |
| Surplus FE206eN sale | planet10 | Swap Meet | 11 | 28th July 2009 10:41 PM |
| Phonic Powerpod k12 Schems? | ProMusic | Solid State | 0 | 4th July 2008 10:49 PM |
| Building the Karlson K12 Need advice | fin1bxn | Multi-Way | 0 | 29th January 2007 02:30 PM |
| Page generated in 0.08089 seconds (74.27% PHP - 25.73% MySQL) with 10 queries |
