Mar-Kel70 in Sweden
Mar-Kel70 in Sweden
Old 7th August 2011, 12:01 AM   #901
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Mar-Kel70 in Sweden
As for bass, wouldn't it be possible to do something like http://www.parts-express.com/pe/show...number=290-407 in a H-frame? I don't need to go that very deep, so maybe OB works for me? Or maybe my room makes OB impossible?
Old 7th August 2011, 03:41 AM   #902
Lerg is offline Lerg  Canada
As far as I know, open baffle usually requires a decent amount of distance between the woofer and the wall. Additionally, after hearing the initial test of the twin EL70, I get the feeling that a really good woofer setup is required to improve upon what it already does.
It makes me curious about building an Exodus Anarchy tapped horn or something similar to take care of the bottom end.
Old 7th August 2011, 09:58 AM   #903
zman01 is offline zman01  Bangladesh
Mar-Kel70 in Sweden
Rullknufs,
I've also read about the distance between woofer and wall that Lerg mentions in his post - so for smaller rooms OB isn't feasible it seems.
Lerg,
Are your drivers broken in yet? A woofer would definitely help with things, but the EL70s should not be too bad themselves.
I am thinking about tapped horns too, with SDX7.
What material have you tried with the Mar-Kel^2s?
Old 8th August 2011, 01:58 AM   #904
The material is baltic birch, and the spacers are curly maple. Veneer is zebrawood, and the EL70s are great for low end response, far better than they should be. The EL70s that I put in for testing were not broken in, the EL70eN that will find the cabinet as their final home have many hours on them.
Old 8th August 2011, 02:40 AM   #905
Mar-Kel70 in Sweden
Lerg,
I misunderstood you a bit earlier - I though you had found the bass response lacking ... you had actually meant a nothing short of a really good woofer will have additional impact on the low end that the dual EL70 already delivers. Good to know - my Wessex is nearly finished.
By material I had meant music you played on them for testing.
-Zia
Old 9th August 2011, 03:16 PM   #906
Rullknufs's Avatar
Mar-Kel70 in Sweden
I've built a pair of (unsteady) stands today.
Tried some listening now and WOW what a difference in soundstage. They are approximately 90-92cm tall and right now the inner walls of the speakers are around 150cm apart from eachother. Can't move them more without changing cables and i'm not in the mood for that at the moment.
Picture is coming later tonight. In my dusty work clothes from a 5 hour job today with dad building a house (sort of).
Old 9th August 2011, 07:52 PM   #907
Rullknufs's Avatar
Mar-Kel70 in Sweden
Phone-camera. Not the best but you can see the stands :P
I'm planning on making a 6mm thick plank of the same material to put on the front of the speaker, making a hole for the driver and sanding the edges.
Also going to put the planks of the stands in a concrete plate to get it more stable and putting some sort of plate on top. But this works for now, but don't touch the stands or the speakers because it's really wobbly!
Old 9th August 2011, 08:42 PM   #908
chrisb is offline chrisb
Thick stone tiles or cut-offs from quartz kitchen countertop shop's sink cut-outs make great bases for stands. Stick some felt pads on the bottom and attach a small square of wood to the uprights and glue with silicone to unsealed stone surface and you'll have a pretty sturdy stand.
They just keep getting better don't they ?
Or actually your brain is normalized to the patterns of their particular signature & "distortions" and can concentrate on decoding the information. The relaxation in your listening in not all in the components' break-in, much is in your head.
kinda burnt out - taking a break
Old 9th August 2011, 09:06 PM   #909
Rullknufs's Avatar
Mar-Kel70 in Sweden
I'm actually going to cast a concrete slab and stick the planks parallel into it with maybe 10-15cm distance between them. Haven't decided on what to have as a top-plate but i guess i'll find something.
By the way, guess what these stands costed me (including the pieces that i'll have for the baffle later on).
68 SEK or around $11
My dad visited the local sawmill to buy some planks for a doghouse we're building (and then selling) and he got some pieces for me, and lots of other planks all for free. Apparently they were "leftover parts", even though they were 1-3.5m long :P
Old 9th August 2011, 11:29 PM   #910
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Mar-Kel70 in Sweden
Similarily i just got all the material i need for my next geodesic dome (8' greenhouse)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Mar-Kel70 in SwedenHide this!Advertise here!
Phonic Mar 6 Amp kinser Solid State 10 29th October 2014 12:57 PM
Phonic - MAR 4 mudanov Instruments and Amps 1 4th August 2011 01:44 AM
Mar-Ken10^2, double the love planet10 Planet 10 hifi 21 16th November 2010 03:38 AM
questions regarding Mar-Ken10 plans zottinger Planet 10 hifi 6 10th August 2010 09:37 PM
