Mar-Kel70 in Sweden
Mar-Kel70 in Sweden
Old 31st May 2011, 05:58 PM   #831
chrisb is offline chrisb
Originally Posted by Rullknufs View Post
I have read a lot about the Tysen
One foot, should be possible. I don't want to place the speaker too close to the corner anyways. But as i've said many times before. Will it work? I mean, one speaker will stand right next to an open door, and the other will stand in a corner. If the driviers can be mounted on the side i guess that makes it much easier making a stand of the cabinet.
will it work in the sense of giving you more output in the lower frequencies than the EL70s alone - certainly
if you're very limited for space, perhaps front firing would provide more placement flexibility in regards to side walls, etc. - if I recall the room correctly, you are rather limited for adding more boxes
like my mind, this space intentionally blank
Old 31st May 2011, 06:00 PM   #832
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Mar-Kel70 in Sweden
Well, the width of the whole setup will be limited. I don't want to place the right channel speaker too far into the corner, and the left channel speaker can't stand in the door. And i'll have to fit an equipment rack inbetween the two speakers. Having front-firing woofers will fit, although i guess it will be difficult making a stand high enough maintaining a reasonable volume of the cabinet.
Old 31st May 2011, 06:09 PM   #833
zman01 is online now zman01  Bangladesh
Mar-Kel70 in Sweden
Rullknufs, you know I want to build the EL166 MLTLs with single woofer/cabinet - the room I have in mind is on the modest side - around 12 x 14. Is your room bigger? My guess is too much bass/LF in a small space isn't ideal either.
Old 31st May 2011, 06:25 PM   #834
Rullknufs's Avatar
Mar-Kel70 in Sweden
I guess my room is about the same size.
Old 31st May 2011, 06:35 PM   #835
bingo
Old 8th June 2011, 03:24 AM   #836
Mar-Kel70 in Sweden
Dave,
Read that MTM design does not usually have good dispersion characteristics - fact or fiction? With the EL166 MLTL designs, Is it possible to go trapezoidal like Tysen and can that help create taller listening profile?
-Zia
Old 8th June 2011, 04:56 AM   #837
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Mar-Kel70 in Sweden
If you XO at the frequencies you usually see, indeed this can be an issue.
If you XO really low like i did, the driver sare effectively co-incident and all those problems go away.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th June 2011, 07:24 AM   #838
Mar-Kel70 in Sweden
dave
And that's where a quality full range driver can be of help, right? Help me cross smoothly at lower frequencies.
-Zia
Old 8th June 2011, 07:50 AM   #839
frugal-phile(tm)
planet10's Avatar
Mar-Kel70 in Sweden
Yes. You get lobing issues with 2 drivers when the distance between them starts getting large compared to the XO frequency.
At 333 Hz a wavelength is ~40" long. At 2kHz is is under 7". Ideally the centre-to-centre driver distance is 1/4 wavelength, 1/2 wavelength you are starting to have issues.
C-C on my MTM is about 10". In the SEAS Thor it is about 11".
dave
Old 20th June 2011, 03:40 PM   #840
Rullknufs's Avatar
Mar-Kel70 in Sweden
Streets Of London by CM Carlsson on Spotify
Playing it out loud and the Mar-Kel70 fills the whole room with the music. Sounds really really good!
Speaker plans are set on ice for the moment. Saving money for travelling instead. Spain two weeks in august. Slovenia in april. Germany, Czech Republic and South Africa in june/july next year. And if i still have money left i'll go to Shetland islands in the winter after that for Up Helly Aa
Mar-Kel70 in SwedenHide this!Advertise here!
Phonic Mar 6 Amp kinser Solid State 10 29th October 2014 11:57 AM
Phonic - MAR 4 mudanov Instruments and Amps 1 4th August 2011 12:44 AM
Mar-Ken10^2, double the love planet10 Planet 10 hifi 21 16th November 2010 02:38 AM
questions regarding Mar-Ken10 plans zottinger Planet 10 hifi 6 10th August 2010 08:37 PM
