Mar-Kel70 in Sweden - Page 73 - diyAudio
Old 28th April 2011, 01:21 PM   #721
kec is offline kec  United States
kec's Avatar
If you like percussions try the SACD version of Peter Gabriel's Passion. Excellent! Even the standard CD is good.
MSI E350IS mITX > Foobar > SPDIF > miniDSP 4X10 > Crown XLS1000 > ?
Old 28th April 2011, 06:30 PM   #722
chrisb is offline chrisb  Canada
this is what it's all about - getting excited about the music
amazing that these little guys can do that, huh?
... so, not as easy at it sounds, this letting go thing
Old 28th April 2011, 06:54 PM   #723
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
Aye.
I've been thinking about projects i'd like to do in the future. Like a Troels DTQWT as a final build. I expect it to play like speakers for $20k or more. I've found that the Burmester B80 could be built for less than one tenth of its price
Old 28th April 2011, 07:08 PM   #724
frugal-phile(tm)
planet10's Avatar
Having lived with a single FR, you might find yourself dissappointed with something like the DTQWT (which, from a theoretical POV has a fatal flaw besides the XO).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th April 2011, 07:10 PM   #725
Rullknufs's Avatar
dave
Well, a single FR wouldn't be able to achieve the same SPL as the DTQWT would. I don't see how a FR driver would play with high spl at ~25Hz.
What's the flaw you're talking about? And what's the problem with the XO?
Old 28th April 2011, 07:31 PM   #726
frugal-phile(tm)
planet10's Avatar
A single FR wouldn't play as load, but a FAST could likely.
The fatal flaw is that the midrange is going to be modulated by the bass drivers since they are in the same enclosure. It would also be interesting to see a sim, since most voigts get quit rippley without some sort of mass load.
XOs are evil, if one needs to use one, it should not be in the ears most sensitive area (ie 2-4k) and drivers need to be real close (relative to the XO frequency, 1/2 w/l).
DTQWT might work fine (probably does witin the context) and i could be out to lunch, but it is hard to imagine not being able to take the same bass drivers, a pair of Alpair10.2 and an extra amp and not be able to come up with something more seamless for less money.
dave
Old 28th April 2011, 07:45 PM   #727
Rullknufs's Avatar
dave
If i want to reach house-rumbling sound levels? I feel that i can't really play loud enough with my Mar-Kel70. And for rock music it sounds like it gets too much for one driver. Sounds completely different (and better) on my headphones (yes i know it's also like full-range).
Music i listen to (and i like to listen as loud as possible) is like this
Slipping Into Coma - Raised Fist - Spotify
Age of Rage - Corroded - Spotify
The Walk - Periphery - Spotify
Legion - Slaughterlord Cover - At The Gates - Spotify
Numb - Disturbed - Spotify
And with a floorstander it gets easier to place them compared to standmounts and separate subs. I could use the Reckhorn S-1 for XO, since it's AFAIK a good XO. But i'd need several amps, and that brings the costs up.
Old 28th April 2011, 08:02 PM   #728
frugal-phile(tm)
planet10's Avatar
FAST your EL70 and just see how much more can be had out of them...
My suggestion was for A10.2 which being larger will have more dynamic capability. One should be able to easily aquire an amp within the budget saved from A10.2 vrs midbass+waveguide tweeter and all those XO parts (the big coils are $73 each all by themselves)
dave
Old 28th April 2011, 08:10 PM   #729
Rullknufs's Avatar
Have no subs to FAST my EL70 right now.
And if i XO at 100Hz i still don't know how loud i dare playing before frying the voice coils. I have the S-1 somewhere in my room. Could hook it up tomorrow. AFAIK it's 24db/octave HP-filter in it, could try that.
Old 28th April 2011, 08:12 PM   #730
zman01 is offline zman01  Bangladesh
Rullknufs,
I am no expert, but maybe you should try the Micro Towers (bi-pole design)... Chrisb says bass is huge with 2 EL70/cabinet.
Otherwise as Mr. Dlugos has pointed out you should consider FAST... I am in love with FR when it comes to most of the music, but not so when it comes to metal or thrash. the BIBs with Fostex FE166en which sounds spacious and dynamic on other types music sound much smaller and thinner when it comes to metal... For me I have realized that will probably have to go FAST in the long run... rgd headphones I have always had my best metal/thrash listening on headphones.
I have Super Pensil 12s and Castle MT made though... need to try them out first.
-Zia
Phonic Mar 6 Amp kinser Solid State 10 29th October 2014 12:57 PM
Phonic - MAR 4 mudanov Instruments and Amps 1 4th August 2011 01:44 AM
Mar-Ken10^2, double the love planet10 Planet 10 hifi 21 16th November 2010 03:38 AM
questions regarding Mar-Ken10 plans zottinger Planet 10 hifi 6 10th August 2010 09:37 PM
Copyright 1999-2017 diyAudio
