Mar-Kel70 in Sweden - Page 124 - diyAudio
Old 21st December 2012, 11:00 AM   #1231
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
The biggest difference is probably the lack of cabinet resonances in the lower midrange region.
I was just listening to some Paul Carrack and I noticed the voice is much "cleaner" than before. I haven't run any sine sweeps yet with these cabinets, but I remember I had some nasty action at ~200Hz with the old cabinets.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 30th December 2012, 09:09 AM   #1232
Rullknufs's Avatar
Guys, I need som help now.
I was glueing the Oy speakers over night and when I was loosening the clamps today one of the spacers had stuck to the baffle. I tried to bend it loose with my hands but I couldn't. Had to use a hammer to knock it away and it brought part of the baffle with it.
Old 30th December 2012, 09:10 AM   #1233
Rullknufs's Avatar
What should I do? Try to peel the missing part off the oak block with a razorblade and if it works try to glue it back in place?
Old 30th December 2012, 09:27 AM   #1234
frugal-phile(tm)
planet10's Avatar
bondo time. then veneer or paint.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th December 2012, 10:39 AM   #1235
Rullknufs's Avatar
Bondo?
Well, I used a sharp carpetknife and managed to peel off the birchply bit from the oak. I will see if I can glue it back to place to fill up the hole a bit. I try to repair it as good as I can and then I'll see if I will veener or paint them.
Old 30th December 2012, 01:48 PM   #1236
jimbro is offline jimbro  United States
At least you know your glue is strong! Kind of hard to tell just how big the damaged area is but it looks like there is not much figure there so may be easy to patch if you have some spare. If you're careful it probably wouldn't be noticeable to anyone but you. I have a little router guide that makes perfect patches easily so might be an opportunity to buy a tool!
Old 30th December 2012, 02:50 PM   #1237
Rullknufs's Avatar
How do you mean? Like routing out a bit and then put a patch in the routed hole? Might work if I get it done right, but I'd most likely have to ask somebody more experience. I might contact the guy who did the 45 degree cuts on the dMar-Kel70T speakers and see if he can do something.
And yes, the glue is really really strong
Old 30th December 2012, 06:03 PM   #1238
TerryO is offline TerryO  United States
TerryO's Avatar
dave
Hello.
Did somebody call my name?
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 30th December 2012, 08:20 PM   #1239
This will give you some idea - Making Inlays With A Router - NewWoodworker.com LLC
Old 30th December 2012, 08:52 PM   #1240
Rullknufs's Avatar
Well, that would definitely be an option.
But I have had the speaker standing in my room now and it is not so very visible now and I haven't done anything to it yet. There's still some darker pieces of oak there which I will remove. I will try the glue/bondo option first. If I'm not satisfied I will try an inlay and if nothing works I will either let it be or paint them.
Phonic Mar 6 Amp kinser Solid State 10 29th October 2014 11:57 AM
Phonic - MAR 4 mudanov Instruments and Amps 1 4th August 2011 12:44 AM
Mar-Ken10^2, double the love planet10 Planet 10 hifi 21 16th November 2010 02:38 AM
questions regarding Mar-Ken10 plans zottinger Planet 10 hifi 6 10th August 2010 08:37 PM
Copyright 1999-2017 diyAudio
