Mar-Kel70 in Sweden
Mar-Kel70 in Sweden
Old 13th October 2012, 07:45 PM   #1191
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Mar-Kel70 in Sweden
The baffle that we sent you was oversized & for the rectangular Mar-Kel (at the time the trapezoid boxes did not exist). The idea was that you would trim it to fit.
Ingvar has done you a deciSize dMar-Kel70T, since that would fit your baffle size -- and it looks like he has done an excellent job. Ingvar should have had his hands on the baffle & a driver to fit everything together. He followed the plans, but your baffle was for a different speaker, something could easily have been worked around if he had the baffle. He was working blind.
And BTW, you will be the 1st person in the world with a set of dMar-Kel70T.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th October 2012, 07:49 PM   #1192
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
Mar-Kel70 in Sweden
So that's why I get the feeling of that they're smaller than my current Mar-Kels then.
What's the difference in sound between the decisize and regular size cabinets?
My audio and DIY blog: http://phimusic.blogspot.se/
Old 13th October 2012, 08:15 PM   #1193
frugal-phile(tm)
planet10's Avatar
Mar-Kel70 in Sweden
The full size are 13 litre, the deciSize 9 litre.
No-one has heard the deciSize ones yet. And the quality differences in material are likely of greater significance than the different boxes.
12mm partical board vrs (18mm) quality ply, the later should have a big edge in DDR.
In theory the deciSize will not go as low, but we have founf that the trapezoid enclosures have a lower diffraction signature vrs the rectangular enclosures.
dave
Old 13th October 2012, 08:25 PM   #1194
Rullknufs's Avatar
Mar-Kel70 in Sweden
Ah, okay
Old 13th October 2012, 08:43 PM   #1195
ingvar ahlberg is offline ingvar ahlberg  Sweden
ingvar ahlberg's Avatar
As said above, iŽll cut new baffles for the d version, i need the mechanical data of the driver, overall diameter, bolt circle diameter, baffle hole diameter and depth of sinking, could You mail me this Dave?
Ingvar
Old 13th October 2012, 08:47 PM   #1196
Rullknufs's Avatar
Mar-Kel70 in Sweden
Driver information could be found here http://www.creativesound.ca/pdf/CSS-...ata-080909.pdf
Very kind of you to cut new baffles for me, Ingvar.
Old 13th October 2012, 09:56 PM   #1197
Rullknufs's Avatar
Mar-Kel70 in Sweden
Dave (or Chris), what's the best way to assemble the cabinets?
I was thinking that starting with the bottom and back panels, making sure they're right. Then the outer sides with port spacers already stuck on them as they shall be. Now the V is formed. Then the inner sides followed by the brace. After that the baffle and then finishing with the top piece?
Old 13th October 2012, 10:01 PM   #1198
chrisb is offline chrisb
Ingvar: if you're machining the rebated driver cutouts by CNC, I'd allow a fraction of mm ( a "blonde one") oversize for ease of driver fit - particularly if there will be a non penetrating finish ( varnish, lacquer) applied.
I always like to have a driver on hand for dry fitting. In fact with the number of drivers handled over the past decade, we've managed to scrape together "dead" samples of the most common models for this purpose.
kinda burnt out - taking a break
Old 13th October 2012, 10:06 PM   #1199
Rullknufs's Avatar
Mar-Kel70 in Sweden
I'll use wood stain, to keep the nice look of the birchply.
Old 13th October 2012, 10:28 PM   #1200
I was thinking more of what if anything might be applied as topcoat - as often mentioned, I spray several coats of NC lacquer, and that can build enough inside the driver cut out that if it's deadly tight before finishing, the driver can be very difficult to remove if needed.
As for assembly, I like to build the 3 layered side panels first (from the outside in), using blocks clamped or screwed to work surface to ensure alignment of panels, and measured strips between the port spacer blocks to ensure correct spacing and square alignment.
Clamps, lotsa clamps, or air powered brad nailer and short pins
Once those are dried and any glue squeeze on the ends scraped/sanded away, you've got a lot more glue surface area to work with.
Exact sequence will depend on whether the back panel is inset or overlayed. I cut the back end of port spacer strips to the 10` angle and inset the back panel for more glue surface area. Of course, I also cheat and use nail gun.
I don't try to get it all together in one set-up:
Side panels, back and bottom panel - check all for squareness, let dry
Driver brace, let dry then add panel damping - don't occlude port lots
Front baffle, let dry , add panel damping
Top (cut panel damping to friction fit before attaching top)
There are quite a few steps involved, but with today's fast setting PVA glues, you only need to wait a couple of hours max before proceeding to the next stage. Of course if you're using brad nails and will be veneering or painting over, you don't need to wait quite as long between stages - but once it's all together, definitely wait overnight before sanding and finishing.
Mar-Kel70 in SwedenHide this!Advertise here!
Phonic Mar 6 Amp kinser Solid State 10 29th October 2014 12:57 PM
Phonic - MAR 4 mudanov Instruments and Amps 1 4th August 2011 01:44 AM
Mar-Ken10^2, double the love planet10 Planet 10 hifi 21 16th November 2010 03:38 AM
questions regarding Mar-Ken10 plans zottinger Planet 10 hifi 6 10th August 2010 09:37 PM
