#1111 |
Apparently the lower woofer is a passive radiator.
The thing with CD/waveguide is that I'd have to design my own passive filter and I fear that's way above my skill level. Not picking on looks, just getting inspiration ![]() What about the Alpair 12p? Would it be able to play loud enough? In that case maybe an Alpair 12P crossed over to some woofer at like 200-400Hz? That way I would avoid XO in the sensitive area. But how high do the 12P go? Maybe I would need a tweeter?
My audio and DIY blog: http://phimusic.blogspot.se/ |
#1112 | ||
If the WLM Lyra, or any of Martin's other designs, there are numerous on-line reviews that could dispute the assertion of "stupid combinations" - to paraphrase these fora re Zaph - "these guys know their onions" Quote:
6moons audio reviews: WLM Grand Viola Signature MkII disclaimer: as I presume to be the case of many of us here, I've never heard any of the WLM products, but they certainly have the appearance of well engineered designs.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#1113 | ||
If for no other reason than confidence in durability at louder SPLs, I think Ryan's advice to consider something along the lines of Pro Audio components might be your best bet.
#1114 |
Yes, but would these other people be able to make it simple enough for me? I have no experience or knowledge at all when it comes to crossovers and it seems like a very difficult topic to study.
I don't want to play at rock festival levels. As I said, the System Audio speakers I tried a couple of months ago could play loud enough and when I played louder than I'd ever do here at home I hit around 108-110dB peak levels.
#1115 |
Rullknufs: Stick with a multi-way to satisfy your dynamic needs right now. Go crazy and build something nuts. Unless you want to now get away from that and get back into the finesse of a full ranger.
A beta 8a with a passive radiator would make even less bass. That's just silly. Are there subs on the back? As for passive cross over design, there should be a few out there. I think Zilch made an econo wave mini. I have one coming down the pipeline for that driver. It'll be after I do a build using the Delta 10a though. If you can bear a wider design, there's already some 10" and 12" designs available. Chrisb: I've heard the alpha 8a and it can make some bass when ported, but that's still a stupid combination. Why use an effecient pro mid driver for bass duty when you're using an effecient pro mid driver for mid driver duty. Like I said, perhaps there's more to it. I can't read the languages that most of the documenation is in. We're talking about the speaker pictured at the very bottom of the link you posted? It has a beta 8 and an alpha 8... Most of the pictures feature a different driver combination. I think the configuration is worthy of exploration for Rullknufs. Just with a proper woofer rather than an effecient pro mid. |
#1116 |
posting while posting
![]() Yes, but didn't you say those System Audio speakers were crapping out on you? If you find a cross over design you like, I can help walk you through assembly. Especially if it's simple, it's not bad. Or find a design with active settings and use your minidsp. I usually do an active design for everything I build. Perhaps you could scale back from the pro stuff and try a 6.5" 2 way with a subwoofer. I'd still use a waveguide. At high volumes, flush mounted domes crumple. I've been there, done that. They have their use, and I use them all the time, but to really be dynamic and effortless it has to have low end gain from a waveguide. Take this cheesy design for example: Small and/or WAF builds using the Denovo stuff 3rd one down called WAF-2.y. Uses a cheap woofer, cheap CD/waveguide. Has active settings. Now, it's not the most hifi thing going, but it's purpose built. I finally knew I liked this speaker when I played a real dramatic mellow song by Diana Krall at insanely loud levels. It's a quite song so I deceptively kept turning up the volume. Until she really belted a very emotional part of the song at ear splitting levels. Well, that tiny little box with cheap drivers, sounded deadly clean. Tingles down the spine clean. The only dome I've heard come close to that is the CSS LD25x in a waveguide. Which Dave has a design coming for that. That will be more hifi, but cost more. If you're patient, that might be quite the ticket in smaller form and higher fidelity. And if I can keep rambling on like a blabbering bafoon, my EL70 desktop setup, still blows my mind. Best imaging and detail of anything I've heard. Period. < Just doesn't have the realism of sitting back 3m and cranking it > I'm interested to see what alpair 7s could do on my desk. Last edited by tuxedocivic; 8th August 2012 at 05:21 PM. |
#1117 |
6.5" could work, if it will play loud and dynamic enough. Even if I got with an 8" I'd still need a subwoofer to reach that 30-35Hz I want.
I could wait maybe 1½ month, then I have to decide to build something. I'm going to a hifi show in Gothenburg on september 15-17 with my dad and maybe I could get some inspiration there.
#1118 | ||
Ryan:
yes, even when Srajan and manufacturers with whom he may dialog in such lengthy reviews both write in English, the prose is oft "otherworldly / arcane" enough that it might as well be Norse, but FWIW here are some snips that I think describe the current configuration of the Lyra II that Niklas mentioned several posts above: Quote:
so exactly what is the mid-bass driver compliment and enclosure tuning configuration of the current LyraII - I gave up google-searching to attempt to ascertain that after a few minutes - your guess is as good as mine what is the PAC, you ask? Quote:
Now, from the ridiculous to the sublimely affordable - how about those EL70s? - maybe I said before how freaking great I think they are. In the application you envision ( small desk-top/near field) I think you could expect the Alpair7 to do image, top end and inner detail like crazy, but not to deliver anywhere near the bass of the EL70
#1119 |
Hmm, ya I have know idea what drivers they have in there now. The final sentence about it being a 2.5 way still leads me to believe it's a single beta 8 over a single alpha 8. Who knows.
Yes, alpair 7 may be in order some day considering my daughter thought dustcaps were toy car horns
#1120 | |
| Phonic - MAR 4 | mudanov | Instruments and Amps | 1 | 4th August 2011 12:44 AM |
| Mar-Ken10^2, double the love | planet10 | Planet 10 hifi | 21 | 16th November 2010 02:38 AM |
| questions regarding Mar-Ken10 plans | zottinger | Planet 10 hifi | 6 | 10th August 2010 08:37 PM |
| Phonic Mar 6 Amp | kinser | Solid State | 8 | 11th October 2007 11:05 AM |
