sharing the sounds of fullrange speakers - can it be done?
Old 5th April 2010, 06:54 AM   #1
freddi is offline freddi  United States
freddi's Avatar
Default sharing the sounds of fullrange speakers - can it be done?
can one get some or any semblance of what a speaker sounds like from recording it and playing that recording back - say on headphones? Here's FE206EN in a 1954 design "Karlsonette" - I'm not sure how much of the impression stayed in the recording. Its interesting to see on Audacity the differences in left and right dB for recording just one cabinet. My Zoom H2 was at about standing ear height and maybe 12 foot back. YouTube - "Karlsonette" 1954 twelve inch Karlson speaker with FE206EN
Old 5th April 2010, 07:55 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I doubt it...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th April 2010, 09:14 AM   #3
Nanook is offline Nanook  Canada
Nanook's Avatar
Default sharing sounds...
the only way that I could consider this would be to set up a "reference room", using exactly the same speaker locations and equipment, including microphone(s), and recording media. It could be instructive. It may give at least an impression of some of the differences. But it may not. Great music on the YouTube video by the way (Ry Cooder? sounds like something he might have been involved with...)
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 5th April 2010, 01:51 PM   #4
LineArray is offline LineArray  Germany
Using an artificial head could possibly give an impression.
Kunstkopfstereofonie - die fast reale Tonaufnahme
But even with best microphones, you still have to rely on the quality
and kind of equalization of the headphones used by the "remote" listener.
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 7th April 2010, 10:07 PM   #5
el`Ol is offline el`Ol  Germany
One can hear that the Fostex in the Karlson cabinet gives good bass. Does it really have the right parameters for the Karlson?
Old 10th April 2010, 05:25 AM   #6
freddi's Avatar
going by ear I'd say they're "right enough" - its a bit "warm" yet bass drum has excellent overtone structure, vocals in general sound better than my BK20 w. 1772.
Old 11th April 2010, 06:54 AM   #7
freddi's Avatar
here's a brief snippet of BK20 BLH with W8-1772 followed by the old Karlson 12 with FE206EN (stock new 206) - there's no change on the amp/TVC setting - there's a slight difference in position as the cabinets were side by side against one of my Klipschorns. The fixed picture on the video is 1772/BK20 wav followed by K12/ FE206EN wav (I probably could have placed the mic better)
YouTube - Compare Karlson to Fostex speaker
Old 11th April 2010, 06:56 PM   #8
Greg B is offline Greg B  United States
The differences are surprisingly apparent considering the limitations. I'm listening on my old pair of Senn HD600 plugged straight into an EMU 0404. The second track sounds pretty close to a live recording of the band, while the first sounds more compressed and conventionally hifi. I wonder though how much is due to the different drivers vs the enclosures.
Old 11th April 2010, 09:26 PM   #9
freddi's Avatar
I think some of its from the Karlson as my early 8K is loaded with a 1772 and has a lively sound (60's model 8K currently has Panasonic "metal" = good sound too but less top octave energy than 1772) - if I can get into a mood to be made ill & miserable from Karlsonette's loose shredding rockwool, I'll swap speakers and do comparisons - maybe:
(1) record 1772/BK20 (2) record Karlsonette/FE206E - (3) swap 1772 into Karlsonette and record whatever reference track at same level, etc. (4) load 206EN into BK20 to get another baseline - - -what I really need to do is to make a custom short and concise test track with:vocals, violin, drums, etc. - For just a track or two of music what would you pick? My recording method has one extra analog step as H2 isn't recognized via USB and its output is fed out the headphone jack into a soundcard - might need firmware update
Old 12th April 2010, 06:10 AM   #10
freddi's Avatar
hey Greg B - here's a composite track played: (1) Karlsonette/FE206EN (2)Tangband W8-1772/BK20 BLH (3) Karlson 8/ W8-1772. The 17.25" tall Karlson sitting on the floor is at a disadvantage for the mic height. The sax which is spectacular on K15 with good coaxial isn't quite as good on these single-drivers - I suspect power response vs off axis can be better on the coaxials using decent compression drivers.
YouTube - Karlson/Fostex vs Tangband 1772 BLH vs little Karlson Tangband 1772
sharing the sounds of fullrange speakers - can it be done?Hide this!Advertise here!
fullrange speakers for sale adason Swap Meet 4 11th June 2006 08:00 PM
www.Fullrange-Speakers.com??? theNoid Full Range 11 22nd September 2005 10:38 AM
Tubes and fullrange speakers! barossi Swap Meet 1 16th November 2004 05:13 PM
(Eton woofer problem) Speakers almost done, but bass sounds boomy Jimmy154 Multi-Way 47 14th August 2004 12:06 AM
need help : fullrange speakers project punk Multi-Way 24 28th February 2003 09:47 PM
Copyright ©1999-2017 diyAudio
