Wide range surround speakers? - Page 2 - diyAudio
Old 11th July 2011, 03:36 AM   #11
Bigun is offline Bigun  Canada
Bigun's Avatar
I have projector with a DIY painted screen. As a result the front L and R speakers are widely separated and a middle speaker is necessary when I have several people sitting in a row since not everyone can sit in the 'sweet spot'. The middle speaker carries a lot of information, especially the vocals and having 3 speakers up front makes it work.
It just happens that I have a pair of commercial 2-way floorstanders for L and R, I'm sure a pair of full range speakers would have been suitable. But they would have to have good bass extension, certainly better than the 6 litre boxes I built which were designed to work down to 80Hz at best. My own experience is that I really enjoy having good LF response from the front speakers (and they are PMC MLTLs).
Pashley, to answer your question. Based on my limited experience, I don't recommend 'audiophile' drivers like the late lamented Fostex FE127 as they appear to me to need big boxes to provide any bass and in my boxes they are seem lacking for Home Theatre (IMHO). I'm about to try some 4" sized CSS EL-70 drivers for the surrounds, although the new CHR/P-70 from Mark Audio which are due out next month may be as good or better. I'll be trying them in something similar to the planet10 mMar-kel70 enclosure.
p.s. I would add that if I were listening to movies in a smaller space than an open basement, I'd would consider smaller speakers all around. I know one person has built a 5.1 system around my Martello speaker design which is a 3" driver in a 2 litre box.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 20th July 2011, 07:21 PM   #12
theJman is offline theJman  United States
Well, if a 3" driver would suite your needs here's a very simple design that might work...
Old 15th November 2012, 10:23 AM   #13
Pashley is offline Pashley  Canada
Pioneer have an 8" full range, claimed response 39 - 16K Hz, 91 Db @ 1 W 1 m. Parts Express offer them for $14, less if you buy several.
GRS 8FR-8 Full-Range 8" Speaker Pioneer Type B20FU20-51FW 292-430
The THX spec wants bipolar speakers for surround sound. Linkwitz says he uses single speakers pointed up, fine for music but not ideal for movies. Lots of people use ordinary full range or two-way boxes.
I'm thinking four of those Pioneers per box, wired series-parallel. One in front, one straight up, two on an angled back.
Old 15th November 2012, 03:27 PM   #14
chrisb is offline chrisb  Canada
as well as this new driver might work for the application, note the qualification/disclaimer of "type" in the part number i.e. IINM this is not a "real" Pioneer
with as many drivers per box as you're envisioning, physically smaller drivers could very well work quite satisfactorily - I've got my own favorites, but you pick your own
if these are for the surrounds, just how large is the venue?
on hiatus
Old 27th November 2012, 10:29 PM   #15
the venue is an ordinary living room, not huge. i like those 8" drivers because they are cheap and fairly efficient. Probably i should look at smaller wide range drivers too. Suggestions?
Old 27th November 2012, 10:38 PM   #16
Quite apart from choice of driver, what do people think of the notion of using four wide-range drivers in a surround speaker?
I once heard Bose 901s carefully set up and with a good amp; they sounded awfully good to me, but so have various other systems and I am not even slightly tempted to use 901s for my main speakers. I think, though, that in surround speakers the direct/reflected mix might be ideal. THX seem to agree since they want diploe surrounds.
Old 27th November 2012, 11:04 PM   #17
frugal-phile(tm)
planet10's Avatar
I see no need for 4 drivers. you could get 2 drivers much better than the GRS (generally regarded as a poor substute for the well liked Pioneer BOFU)
Like the Splayed surrounds in this document http://frugal-phile.com/boxlib/P10fr...dix-191209.pdf
The CHP70.2 should readily substitute for the CHR if you desire a paper cone solution.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
New 8'' wide range speaker Igor V. Kutuzov Full Range 75 6th April 2014 07:47 PM
Wide dispersion speakers using full (wide) range drivers ozziozzi Full Range 1 28th December 2008 06:13 AM
Good wide range mid. neutron7 Multi-Way 3 28th January 2008 03:33 AM
New Reference Speakers with Full/Wide-Range Driver surf,sun&sound Full Range 206 15th June 2006 12:27 PM
Wide range horn confusion.. Rocky Multi-Way 58 2nd May 2004 05:22 AM
Copyright 1999-2017 diyAudio
