Hi all
I noticed that a few vintage Philips full range speakers have part numbers starting with ADZ instead of usual AD (e.g. ADZ XXXX AM). Does anyone know what the prefix letter Z mean? Kind regards, James |
#2 |
Text in a Dutch paper: "luidspreker met verhoogde gevoeligheid in het frequentiegebied met 3000 Hz als middelpunt". I Will try to translate to English...
Drivers with higher sensitivity in the frequency around 3000 Hz (3000 Hz as center) |
#3 |
Thank you jakeb2.
I wonder what the significance of that is? For comparison, I have seen a 9710/M8 response curve and it has higher sensitivity at 8kHz. Kind regards, James |
#4 |
According to my Philips databook, Z as a suffix denotes a notably higher response around 3kHz (such as used in portable equipment for voice reproduction), while M denotes a smooth and extended frequency response (typically dual cone full range).
Z in the prefix area is not described.
Steerpike's Toybox |
#5 |
3khz? Aha! That would be the model with 'more cone breakup'.
I must confess my favorite music is that made by the Rolls Royce Merlin. |
#6 |
@Steerpike, you're right. 'Z' as a suffix. Sorry topicstarter.
According to the paper useful for smaller amplifiers, small radios, intercoms and car radios. There's also a 'Y' which Philips recommends for these applications. A higher sensitivity at 2000...6000. Here's the paper I downloaded from Internet a while ago. I think from mfbfreaks : Official Site, but I'm not sure. |
| Philips AD 51654/SQ 8DC | exurbia | Multi-Way | 1 | 30th November 2009 02:11 PM |
| original philips AD-9058 | takiskatsikas | Tubes / Valves | 1 | 8th November 2009 08:20 PM |
| WANTED: AD 0211/SQ4 ; AD 0163/T8 for philips MFB vintage | anton-sa | Swap Meet | 3 | 28th February 2008 03:51 PM |
| Philips AD 02110 SQ | Erlingg | Multi-Way | 2 | 28th March 2006 04:29 AM |
| Philips AD/12100/W8 | intraday56 | Multi-Way | 1 | 13th September 2005 06:31 AM |
| Page generated in 0.09822 seconds (72.92% PHP - 27.08% MySQL) with 11 queries |
