CHR/EL 70 cabinet decision - Page 4 - diyAudio
Old 4th April 2010, 07:45 AM   #31
torrence's Avatar
Originally Posted by mdikovics View Post
Wavne and Torrence,
Also, the cost of doubling up is going to open up driver choices that are twice the price. But generally speaking if you are interested in a full range design, using two is not as good as finding a single driver to do the job.
This was actually going to be my next question. Is there a more expensive 8-ohm ~90 dB full-range driver which is well suited to a small (8-10 liter) sealed or ported enclosure?
Old 4th April 2010, 08:04 AM   #32
Scottmoose's Avatar
The Fostex FX120 is about on the money at 89dB 1m/1w & 7.3ohm (8ohm nominal) impedance. That's a lovely unit; not large, it's a 4 1/2in driver, with about 10in^2 pistonic CSA but 8 - 10 litres isn't much Vb to be working with, & in terms of physical size, pretty much rules out anything much larger. Fostex also have their F120a as well; similar sensitivity & impedance, & an AlNiCo motor. It's about double the price of the FX120 though, so as such, I always felt the FX was the canny choice, esp. as it's very close in performance terms & has a little more Xmax too.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 5th April 2010, 12:22 AM   #33
chrisb is online now chrisb  Canada
I've had opportunity to hear both the A & X in Fonkenesque enclosures - but not unfortunately able to directly compare them. I could easily live with either, but certainly agree that the lesser priced unit offers great value - maybe 90-95% of the performance for far less coin.
come to think of it, I could easily live with both, and for that matter multiples of several of Mark Fenlon's continually evolving line of metal and paper coned drivers
on hiatus
Old 5th April 2010, 02:29 AM   #34
frugal-phile(tm)
planet10's Avatar
I treat FX120 & F120A the same when it comes to boxes. Vented i wouldn't go less than 10 litre. Fonken-steen (20 l?) showed room for enven more Vb. I have an unbuilt design of 30 litres, the intention of which was to explore the limits.
89 dB is optimistic for these...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th April 2010, 01:41 AM   #35
markaudio's Avatar
Talking of twinning Markaudio drivers:
Here's the anechoic chamber test results from work I did for an Australian company early last year. The frequency response is well balanced for 2 X CHR-70 (from memory) in a 9 litre BR with twin ports. There's no filtering of anykind on this set-up.
What's interesting to note is the relative near flat response that doesn't show any significant variations in output compared to a previous single driver anechoic tests.
This measurement was taken at 1 metre distance from the cabinet. No differential and combing issues were evident on this and other tests we ran at the time.
Cheers
Mark.
chr-70 designs. castlesteve Full Range 17 1st June 2011 09:27 AM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 01:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 11th January 2010 11:20 PM
Copyright 1999-2017 diyAudio
