CHR/EL 70 cabinet decision - Page 2 - diyAudio
Old 2nd April 2010, 11:15 AM   #11
Wavne is offline Wavne  Canada
By 'void' free, you mean knots and stuff? I'll have to go back and check how many plies the Birch has. I did find one store that had a 5x5 sheet of BB but I think I need more than that. Haven't received Dave's plans yet, but he said he was working on something. Everything here is closed tomorrow so I'll check on Saturday.
Old 2nd April 2010, 12:44 PM   #12
Scottmoose's Avatar
No, voids refer to voids in the plys i.e. missing or loose internal pieces etc.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 3rd April 2010, 02:32 AM   #13
Originally Posted by planet10 View Post
The MA drivers will be a better match to either of your amplifiers.
Both the MA drivers are capable of going quite low so 80 hz is a breeze. Relieved of anything below 80 Hz, they will play louder... still, a pair (or even quad) of drivers per side would let the drivers loaf more ...
dave
What you got in mind Dave ?
Old 3rd April 2010, 06:27 AM   #14
torrence's Avatar
I have also been looking at building small bookshelf speakers, and the demise of the FE167 has made me look more carefully at the CHR70. Does anybody have an opinion on (or better yet listened to) the till-2 design from MA? Double drivers would help recover the sensitivity a bit and present a more gentle 8 ohm load, and given the CHR70 price this seems pretty attractive. Any chance for an 8-literish mini m-di-MA-onken?
-E
Old 3rd April 2010, 07:05 AM   #15
frugal-phile(tm)
planet10's Avatar
Just got power back from being out all day, i'm playing catchup.
Void free means that any knots falling out etc have been filled so that there is wood instead of air.
I've gotta go down stairs and fire up the Mac with the plans on it before i can do get them and do a 1st pass at a cut plan.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd April 2010, 07:09 AM   #16
frugal-phile(tm)
planet10's Avatar
Mar-Kel70^2. Have the 1st pass drawn, need to detail, dimension, check for gotchas and do a cut plan. Should be room in the (optional) false bottom for a single Trio8 or SDX7 for support in the lowest octaves if desired (there is a Wavecor that i find interesting, a Danish manufacturer building some of Scott's & my designs turned us on to it)
Should look like a skinny Fonken167.
dave
Old 3rd April 2010, 07:13 AM   #17
frugal-phile(tm)
planet10's Avatar
The good stuff starts here.
3 sets of betas total in the works.
dave
Old 3rd April 2010, 04:39 PM   #18
torrence's Avatar
dave
Hi Dave,
I have been sort of following this other thread, but none of these dMar-Ken 'betas' are dual drivers, are they? I played around with WinISD a little last night (of which I am a total novice/idiot) but it appears that two CHR70s really prefer a sealed rather than a vented box in a smaller enclosure. There was always a 3db hump at around 100 Hz no matter where the port was tuned. I was wondering if this generally would sound OK, compensate for the slight low-frequency attenuation seen on the driver response curves, or whether stuffing a slotted port (aperiodic) would tame this to an acceptable level?
Old 3rd April 2010, 06:04 PM   #19
dave
Sounds quite nice. I'm definitely curious to see a 4 driver variant as I love fullrangers as well as some volume.
Old 3rd April 2010, 10:54 PM   #20
frugal-phile(tm)
planet10's Avatar
That is my feeling. 8-12 litre sealed for 2 drivers. I's tend toward the big end. A dMar-Ken70 would be in the 20 litrish size. Not hard tp come up with.
dave
chr-70 designs. castlesteve Full Range 17 1st June 2011 10:27 AM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 02:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 12th January 2010 12:20 AM
Copyright 1999-2017 diyAudio
