Anyone tried W5-1611SA  in a sealed box?
Old 29th March 2010, 05:18 AM   #1
Zoodle is offline Zoodle  Australia
Default Anyone tried W5-1611SA in a sealed box?
http://www.tb-speaker.com/detail/1208_03/w5-1611sa.htm
Has anyone tried this driver in a sealed box?
It has qts of .44, which seems borderline for sealed, or am I being pessimistic?
Also, to anyone who has tried this driver (in any type of enclosure) -- how do you find the treble quality?
Thanks in advance.
Old 30th March 2010, 11:40 AM   #2
jhohm is offline jhohm  Germany
jhohm's Avatar
Hello,
look here :
http://www.hifi-forum.de/index.php?a...d=267&thread=8
(german Language)
cu Jörn
Old 30th March 2010, 03:38 PM   #3
pauldune is offline pauldune  Netherlands
pauldune's Avatar
Hey Zoodle,
I have a pair, (not in a sealed box) see conical horn damping material...
The treble is a bit lacking. Compared to my fullrange speakers I was missing a lot of details. But with a side firing philips tweeter it is not so bad. Details are ample now, and the side firing tweet isn't disturbing the soundstage.
Old 30th March 2010, 04:12 PM   #4
pauldune's Avatar
Originally Posted by jhohm View Post
Hello,
look here :
(german Language)
cu Jörn
Jorn, That is a bass reflex enclosure, not sealed....
Gr. Paul
Old 31st March 2010, 04:09 AM   #5
Originally Posted by pauldune View Post
The treble is a bit lacking. Compared to my fullrange [two way?] speakers I was missing a lot of details.
Thanks,
Have you heard this (the W5) compared to similar fullrange drive units? If so, which ones?
I currently have 90mm units, and the treble is quite lively. I wonder if a larger, heavier cone might not be as detailed at higher frequencies as a small cone.
Old 31st March 2010, 09:48 PM   #6
pauldune's Avatar
Originally Posted by Zoodle View Post
Thanks,
Woops! typo...My other speakers are 2.5 way mordaunt short 908i.
Not really expensive, but pretty good. Only because of the 3 speakers with large overlap, lobing is quit noticable. If you move your head left/right or up down, the sound changes a lot. But on the other hand, in the sweet spot they sound pretty good.
I'm considering replacing the tangbands for mark audio alpair 10's, to get rid of the supertweeter.
(the tangband are going in the enclosure Jorn proposed, but with a build in permanent rear or side firing tweet)
If I swap them for the alpairs, i'll inform you....
gr. Paul
Old 1st April 2010, 06:25 AM   #7
Yes, please do.
Old 14th April 2010, 08:54 AM   #8
pauldune's Avatar
I swapped them... They sound better than the TB's. But on my SE tube amp, still not enough high. With supertweeter added they were really good..
Old 14th April 2010, 09:02 AM   #9
Thanks for updating. Do you feel the alpairs have better treble than the TBs? (I mean without using a super tweeter)
And how about bass performance? (TB v Alpair)
And the mid range?
I'm considering alpair, so your comments would be useful.
Old 14th April 2010, 09:08 AM   #10
pauldune's Avatar
Yes, bass and treble are both improved. Treble was almost enough. Maybe with a SS amp, it would be enough. My SE tube amp without gfb has a disadvantage there....
gr. Paul
Anyone tried W5-1611SA  in a sealed box?Hide this!Advertise here!
W5-1611sa Jeb-D. Full Range 75 14th February 2013 07:14 PM
Tang Band w5-1611sa question.. Dxvideo Multi-Way 9 2nd January 2013 03:51 AM
TB W5-1611SA vs. MA Alpair7 barackuda Full Range 42 7th February 2011 12:57 AM
Sealed box to OB? mayhem13 Multi-Way 11 23rd February 2009 03:14 PM
sealed woofer box patriz Multi-Way 0 2nd April 2002 10:06 PM
