anyone get/analyze (stock Fostex) FE206En?
Old 27th March 2010, 08:46 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default anyone get/analyze (stock Fostex) FE206En?
gotta pay for one, published specs show ~3 gram reduction of mms giving higher Vas and fs, xmax is rated lower from 1.5mm to now 0.8mm, eta zero higher.
I don't have simulator on my old mac to see various impact - assuming specs and sims are good in the first place
anyone here get FE206En and give it a listen?
New FE206En
http://www.madisound.com/catalog/PDF/FE206En.pdf
old FE206E
http://www.madisound.com/pdf/fostexdrivers/FE206E.pdf
Old 27th March 2010, 09:28 PM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
I'm not sure if they're shipping them yet, although if they haven't started, I can't imagine it's far off.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 27th March 2010, 09:46 PM   #3
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
When i last conversed with my Madisound rep he said they were out of FE206e, and (implied) they were shipping FE206En ...
I'm not happy with the new name... confuses people when i say FE206eN, and what am i to call the new ones? FE206EneN?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th March 2010, 09:55 PM   #4
freddi's Avatar
might you add "P10"? = FE206eNP10 or FE206P10eN (for your well known planet10 handle) - or is the resulting name too long for most folks to remember?
Old 27th March 2010, 10:05 PM   #5
frugal-phile(tm)
planet10's Avatar
That is a good idea... FE206P10eN... it even rhymes
dave
Old 27th March 2010, 10:23 PM   #6
Scottmoose's Avatar
At the risk of being controversial...
Acceleration factor Γ taken in meters per second per second per ampere comes out quite well for the new unit (working with the factory specs. as our baseline -Mark's testing of a pair of 127s seems to suggest that they may be more accurate than we thought; looks to depend on the gear)
FE206E = 770ms^2
FE206En = 872.95ms^2
Less controversially & FWIW:
The new unit with only about 53% of the linear displacement of the old one & the same cone size will be be somewhat more restricted in terms of dynamic BW.
Published EBP for both units is consistant with the claimed figures.
Fhm per Keele
FE206E = 454.245Hz
FE206En = 483.611Hz
Fhm per Leach et al
FE206E = 433.333Hz
FE206En = 463.917Hz
Old 27th March 2010, 10:47 PM   #7
freddi's Avatar
that would be nearly a 6dB dynamic penalty for the new driver if its qt went dramatically up past the 0.8mm xmax and within 206E's 1.5mm window and if 206E were linear within that window. Are there studies of dynamic compression or Dumax type examinations for common fullrange drivers? Could it be crudely estimated with examination of a brief wav of say a big odaiko drum beat compared with a recording of a speaker playing that wav?
Old 28th March 2010, 12:52 AM   #8
InclinedPlane is offline InclinedPlane  United States
InclinedPlane's Avatar
Volume and dynamics mean precisely squat if they can't get rid of those breakup modes, which I'm sure they haven't. How's that for controversial!
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 28th March 2010, 03:24 AM   #9
freddi's Avatar
won't hurt me - unless 206 universally sound crappy I"m going to go for 1.875 cubic foot external bulk Karlson coupler - the HF lobe will be tilted 30 degrees up. Do 206 breakup like 12" multi-rib cone guitar speakers? (I like those even on vocals) - do Nirvana's 8" speakers play better midrange than Fostex?
Old 1st April 2010, 08:45 PM   #10
freddi's Avatar
great looking driver and good strong qes for no break-in or play at all
FE206EN
quick Qts
zooming in for resonances
anyone get/analyze (stock Fostex) FE206En?Hide this!Advertise here!
Audio analyze Williams Audio Solid State 0 7th January 2010 06:51 PM
FE206eN and Alpha 15 in OB? aquapiranha Full Range 30 5th November 2009 11:40 AM
Surplus FE206eN sale planet10 Swap Meet 11 28th July 2009 11:41 PM
WTB: Stock or near stock ART DI/O buzzinghive Swap Meet 0 16th March 2007 10:06 AM
Uk Diyers Wilmslow now stock fostex khush Full Range 1 2nd March 2005 07:18 PM
Copyright ©1999-2017 diyAudio
