Have an old speaker but can not buy any surround that's why I am wondering I any of you tried making their own surround? YOur help will be greatly appreciated. thanks!!
#2 |
There are manufacturers which can deliver surrounds ...
One possibility in making a surround by yourself is putting textile on a form (O-Ring or similar) and soak it with glue. |
#3 |
A long time ago I tried repairing old foam with strips of leather and contact cement...
What type of surround is it? Foam? You can't find ANY surrounds or can't find the exact size surround? You should be able to splice together (cut it and overlap) a fully functional surround from one that's close to the right size. |
#4 |
#5 |
Dear c3conv
I didnt have some 20$ to buy (it didnt worth the cost for these speakers anyway) some descent surrounds, so I experimented with an old idea. Four strips of some packaging plastic sheet, glued radially on the cone. They leave a vent area around the cone edges, which can serve as the bass reflex vent area. It works particularly well for bass-midrange drivers. (For the strips, you can use some thicker cloth or some leather instead). It is important that, before you apply the new surround to have the cone radially centered and held away from its axial rest position . To do this, remove the dust cup and insert some photographic film strips between the center magnet pole and the coil former, pushing the cone in. Make sure it remains at this position for the rest of the job. Then glue the four surround strips at the speakers basket. After the glue has cured, you can glue the strips on the cone. After you are done, remove the centering film strips from the coil former and reapply the dust cup (or place a phase plug over the center pole). On the 8 inch Philips woofer you see on the photo, I applied a decorative touch to hide the ugly looking mod, by placing a half polystyrene donnut over the speaker. It had the added benefit of acoustically loading the cone, as the donnuts inner diameter was a bit smaller than the cones outer diameter. Best Regards George |
#6 |
www.minor-audio.com/bibou/speaker/FE167E_200701.html Showes a FE167E
being rebuilt with a handmade cone,spider and paper surroud. I sure hope I typed that in right. |
| Surround speaker with ribbon | ackcheng | Multi-Way | 1 | 8th March 2010 03:45 AM |
| DIY Surround speaker : please help | cmsajith | Multi-Way | 11 | 3rd November 2008 09:54 PM |
| Designing a rear surround speaker | pjpoes | Multi-Way | 7 | 4th February 2007 12:33 AM |
| Any body want to talk about Lumenwhite speaker? | kevinlin1013 | Multi-Way | 0 | 10th May 2005 06:57 PM |
| Any consensus on surround speaker format? | David Gatti | Multi-Way | 4 | 2nd April 2005 05:09 AM |
| Page generated in 0.09242 seconds (72.56% PHP - 27.44% MySQL) with 11 queries |
