Hi everybody. I would like to build enclosures for Fostex FE166 using back loaded horn technique. Fostex's project is very difficult, with a lot of pieces. The project for FE126En has less pieces but not all of them are straight. So, does it exist a compromise? A cabinet with not so much pieces and all of them straight? Or am I asking for a dream become really? I've evaluated BiB's projects, but I've not room enough.
Many thanks to all of you Ziocalepino |
#2 |
Neither the FE126En or FE166En are particularly forgiving drivers to work with, and if you want a back-horn, then frankly, you have to expect some complexity. That's just the nature of the beast.
The Factory 166 horn isn't an especially difficult build; while it's a large number of pieces, that's not really a big deal providing you're patient & willing to take some time. After all, it's all 90 degree angles, butt-joints etc. Doesn't get much simpler than that. It's a reasonable performer, if not steller. The Factory 126 box is rubbish, quite frankly, and is best avoided. |
#3 |
Well, I thought Fostex project for 166 was better, speaking of sound you can obtain. My goal is to build my own spekers doing really all by myself. Time is not a matter, I can spend months to do this. So, if you (or anybody else) confirm that Fostex's project for 166 is good I can consider this as a challange, knowing that at the end of the work I'll be satisfied. Ok?
Thanks a lot, expecially for your comment about project for FE126 By Ziocalepino |
#4 |
#5 |
Ron's A166 would be my top choice. Not as easy to build of course as there are more complex angles involved; Hiro's a decent box too, but if a BIB is too large, that probably rules it out.
#6 |
Hello
i made this construction, for the low Xmax of the driver as a double horn.
http://www.hm-moreart.de |
#7 |
Hi There,
I built the fostex recommended enclosures. It is not too difficult if you can get your local wood merchant to do all the cutting for you. ![]() That is my cat doing quality control... ![]() Checking the driver fitment... ![]() More checking.... ![]() Getting the wood.... ![]() Dry fitting.... ![]() Just before glueing... You can see where I did some prefinishing on the hard to reach inner pieces (the mouth) ![]() Eventual plugging in... After doing this project (OK I am still finishing them at the moment on the outside) - I have the following suggestions...
I tried a pair of Voight pipes... ![]() Nice sounding but a little lean on the bass side. The upside was that I could again intergrate my sub into the equation... For the life of me I cannot get the sub and the back loaded horns working properly together... ![]() I just built these ones.. Angular spirals... http://www3.ocn.ne.jp/~hanbei/eng-angular.html These have been a major surprise!!! i built them with sceptisism thinking that I would probably bang some cheap drivers in then and use them in the garage. The sound is amazing and very balanced... Conclusion My next project with these speakers is to try Ron's A166 BL horns. I will also try the Bigger is Better option... Why build so many boxes for one driver??? It's a learning experience for me both in terms of the woodworking and the principals and nuance of speaker design... |
#8 |
>>> Why build so many boxes for one driver??? It's a learning experience...
Agree. It also allows you to understand and hear how one box design sounds different than another. Neat pics. Godzilla |
#9 |
Build a pair of Voigt pipes, gain two new hatstands!
#10 |
I also built Ron's A166 BLHs.
Subs built into the corner reflector integrate very well. The only thing i see going for bibs is ease of construction; sound is much smoother, more balanced with austins. |
| Back Loaded Horn with FOSTEX, some questions... | Guijs | Full Range | 135 | 31st October 2009 10:58 PM |
| fostex 206E back loaded horn failure | gerado | Full Range | 76 | 21st May 2009 08:59 AM |
| Page generated in 0.12582 seconds (82.23% PHP - 17.77% MySQL) with 11 queries |
