Playing around with Fostex FF85K
Old 28th March 2010, 06:41 PM   #11
Leffler is offline Leffler  Sweden
Finally an update!
First, let me comment on the boxiness, this has now disappeared completely. I believe this was due to very little bass due to the drivers being new, and insufficient damping of the boxes.
Let me first say that It sounds absolutely unbelievable now they've had a few weeks to wake up!
This is how it looks in front of me right now (unless you close your eyes, then you can clearly see Norwegian singer Kari Bremnes and her band…)
They do look a lot better without the felt, but they gain quite a lot of clearness in the top when it is applied. Without it, they can be a bit too hot in the extreme treble. I'm trying to think of a good looking way to do this…
In the middle of experiments with various port depths. Curiously, they sound more "open" with a port than without. I found the 12cm/ 70hz version to sound best.
The NOS 8" on top of the speaker is intended to be tried as a small desktop sub. Very retro, lacks all thiel info, but without a box it sounds very promising and quite efficient. I'm planning a small sealed box and a small "chip amp" with built in cross over (maximum power is only 6w continuous, so this will be a small affair...)
Current amp (waiting for focus to shift to the SE 6V6 amp I'm planning) is a Revox Modell 40. Very cool Swiss design from the '60s. It sounds surprisingly good, even in the main system!
This is how I've added damping right now. There is a lot of polyester damping in there, but rolled in order not to bend the paper port…
This is how they have sounded best so far. The porting actually made them sound more "open", so I clearly prefer this to the sealed version.
They sounds really good! These drivers are truly special, extremely spacious and open sounding (even though sometimes a little too high resolving for web based services, since overtones comes through with such ease. Compressied sources can truly sound awful…). The dynamics and correctness of timing is absolutely top notch, voices sound superb. I could go on…
However even though they are all right in the bottom, perfectly fine for acoustic music, I have a Velodyne SPL800r to be sold (I have a DD-10 in the main system now) and decided to give it a try, and with this great little sub added… WOW!!!
The sound is crystal clear from deepest end to highest high and really engaging. These are truly little gems! Right now have cut them at about 120hz, and they can play seriously LOUD if required.
Now, next step is to see how the microFonken fares against Fostex' design. The plan is to add walnut veneer to the speakers that win! I also plan to test a miniature 10x10x10cm box as home theater surrounds.
Old 18th June 2012, 12:54 PM   #12
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Wonderfull amp that seems to be in a very good shape.
I have one myself (that is very worn out - the previous owner used it as a bookshelf amp without ventilation).
The main amp amplifies just 15 dB! That might be a reason for the tight bass. It even sounds good on my Quad (but I myself need the extra power of an F5).
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anzaï Zaïka; --> FE103 sigma TQWT
Old 18th June 2012, 08:35 PM   #13
gougigaga is offline gougigaga  France
Nice project !
The bright sound of your speaker is normal it's due to the lack of baffle step compensation. Search about that, you can do it by a RLC filter at the speaker or (cheapest solution) a simple RC filter before the amp at line level
Old 18th June 2012, 08:45 PM   #14
adason is offline adason  United States
adason's Avatar
If you are going to use the sub, let's say 160-180 Hz and below, it helps to limit the low frequencies to the fullrange. Every time I liberate the fullrange from low frequencies, the midrange and heights just shine. Fullrange with sub is just very satisfying configuration.
Good luck!
Old 18th January 2013, 07:06 PM   #15
Default Update a few years later!
I found this old thread and figured it's time for an update!
I built the uFonken boxes for the drivers, and I added teak veneer to them (they were out of walnut...). They look really good, in a very cute way.
I ended up selling my very expensive and absolutely fantastic Marten Miles 3, because I moved to an apartment that made it impossible to get good sound and I lost the motivation to own them. The Velodyne DD10 that I have is actually so good that I let it take over from the awesome Marten speakers from 150hz down, especially in this very problematic room. So, I figured why have big speakers when I cut all the bass from them anyway? To make a long story short, the ufonkens with the FF85k are my main speakers since about 2 years, and I am very happy. I think I am lacking a little bit of mid bass, but with the excellent, tight and tuneful bass, and the really snappy, detailed and "stomp your foot" feel of these little gems, it sounds great.
The uFonkens are driven by a McIntosh MC7100 and a Nuforce AVP17 home theater pre amp that also provides D/A and crossover, currently crossing over to the sub at 200hz.
(Let's see if I can find a picture of how they look now...)
Old 18th January 2013, 07:17 PM   #16
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
I will agree with you, pretty amazing little speakers. The currently available FF85wk takes it up a notch as well.
I have LOTs of speakers here, but of late i seem to be gravitating back to the uFonkenSET with the matching woofTs.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th January 2013, 07:31 PM   #17
Ah, cool that they have been updated, I thought they had been discontinued. Now I can build the remaining five, I am using a 7.1 home theatre pre amp after all... Thanks by the way Planet 10, awesome pages you have that inspired me to take this on! Great work!
A few more pictures I dug up:
the build in progress:
The veneer process was very simple, the veneer was cut to be somewhat larger than the surface to be covered, then regular wood glue was applied and the surface was ironed with a hot iron, and then put in press (using a pile of magazines) while it dried. Very quick, and worked very well! (of course the second speaker looks better then the first, heh)
Electronics...
Comparison with the Fostex box from the data sheet:
There is a picture from a DIY-meet in Gothenburg too, but I can't seem to find it, and I'll take a pic of the current setup tomorrow.
Old 18th January 2013, 07:37 PM   #18
frugal-phile(tm)
planet10's Avatar
There are some slight changes to the venting on the uFonken with the new driver (tuned a bit lower), email and i'll help you sort that out.
dave
PS: I stole one of your pictures to post in the miniOnken gallery. miniOnken/Fonken Picture Gallery
Old 18th January 2013, 08:15 PM   #19
Feel free to use the pics Dave, glad if I can help! Is there also a design that is lika a "real" Fonken? I think I saw pics on the forum, but can't see the plans on the planet10 site?
A few more thoughts. Someone might wonder about the felt used on the front on some earlier pictures, I felt it helped at first, but removed it after a while, I found that the sound was better without.
When the speakers were presented at the DIY-meet, unfortunately they did not come into their own put way into the room without bass support. They could work as detailed PC-spekears, but without a sub the magic is hidden behind the light-weight presentation. I really feel these are tweeters that go down into the mids, rather than mids that try to go up.
Also, links to the build threads on Swedish forum hififorum.nu, with a bit more details for those who read swedish or use Google translate. :-)
HiFiForum.nu - Kan man bygga högtalare i lägenhet? (uppdaterat)
HiFiForum.nu - µFonken- smålådor med Fostex bredbandare
Playing around with Fostex FF85KHide this!Advertise here!
Help with Sansui Woofer +Fostex FF85K for OB SCD Full Range 12 4th December 2008 04:35 PM
fostex ff85k as a mid-hi in 2 way speaker mipop35 Multi-Way 0 1st December 2008 06:13 AM
Fostex FF85K for sale lcholke Swap Meet 3 14th September 2008 07:01 PM
amp for Fostex FF85k tame Multi-Way 0 28th February 2005 08:21 PM
fostex FW208N and FF85K navin Full Range 26 6th June 2004 07:27 PM
